timing issue
Old Jan 15, 2013 | 06:15 PM
aruiz714's Avatar
timing issue
So I am trying to set the timing since I was tooth off...the engine backfires sometimes mostly while granny driving. I set the idle at 700rpm and the timing to 12 degrees. I heard if you got the head resurfaced you have to compensate for it. Any advice?
Old Jan 15, 2013 | 09:12 PM
Did you fix it so it's now lined up correctly?
If you shaved it over .080" then you need to use shims.
If the timing is truly set to 12* BTDC and it has no power, start with reading the spark plugs.
Old Jan 15, 2013 | 10:46 PM
aruiz714's Avatar
True no power. It ran amazing at 10 degrees...sight misfire would be not setting idle right have something to do with it?
Old Jan 15, 2013 | 11:07 PM
aruiz714's Avatar
...and yes lined up correctly thanks to you lol
Old Jan 16, 2013 | 12:03 PM
Is this a turbo or n/a?
If it's n/a, initial timing is 8* BTDC, with vacuum advance disconnected.
If it's a turbo, initial timing is 24* BTDC with TPS disconnected.
How are you "setting the idle" ?
Old Jan 16, 2013 | 06:35 PM
aruiz714's Avatar
It is NA. I raise the rpm to 2000 for 2 min. and adjust.
Old Jun 5, 2013 | 02:48 PM
mixon123's Avatar
If it's n/a, initial timing is 8* BTDC with vacuum advance disconneced And the Gray connector thats plug in the IC unit on the distributor!!!!
I almost on timing issues
mixon123
Old Jun 5, 2013 | 07:54 PM
Superduner's Avatar
seems i am having the same problem with the timing on my 83 zxT engine and will need to adjust the timing on it.
Old Jul 10, 2013 | 09:26 PM
Twiggs280zx's Avatar
Where can I find a "How to" for setting timing? Ive been through the haynes and a rebuild book for the L28 and still nothing. Ive also been through the zdriver and zcar forums and find nothing. Any pointing in the right direction is greaty appreciated.
Old Jul 10, 2013 | 09:45 PM
Distributor timing: Haynes manual pgs 26-27, 44-45
Timing chain (crank to cam) timing: Haynes manual page 77.
I've also posted Haynes / FSM scans on both of these many times.
Old Jul 10, 2013 | 11:11 PM
Im reading it again. Are there any videos on it? I seem to learn better by seeing what I am supposed to do.
Old Jul 11, 2013 | 06:33 AM
Which "timing" are you asking about? Distributor or timing chain? (this thread is about lining up the timing chain correctly)
vegaswinson
23
Dec 22, 2020 05:22 PM
PCressey
Mar 10, 2015 05:23 PM
Solhaven
Aug 4, 2013 04:30 AM
Lesnocker
Mar 24, 2013 09:07 PM
300zgearhead
18
Apr 22, 2009 04:01 PM
