timing? fuel?
Old May 24, 2008 | 11:27 PM
seanzzy's Avatar
timing? fuel?
Ok so here's the deal, i finally got my car back together and got it running. i took it to class to do the ignition timing and it is 80 degrees off (give or take a few). it was still running and driving fine but i let it sit parked at school all day and it wouldn't start. I loosened the distributor and turned it and it wouldn't start until i put it right back into the position it was already in the first place. I drove it home let it sit a few hours and wouldn't start again. So i went back and messed around with the distributor and it ended up starting again in the same place it was already set at and then died once i got to the bottom of the hill pushed it back up messed with the distributor again and now it won't start at all. The fuel lights also going on and i have a little more of a quarter of a tank in there. any suggestions?
Old May 25, 2008 | 09:08 AM
How do you know it's exactly 80 degrees off??? And I'm pretty sure it won't run at all at 80 degrees timing....
Old May 25, 2008 | 11:10 AM
duowing's Avatar
NisTuner
My thoughts lie on the ignition module. If it goes bad it can work intermittently, and it can really throw off your timing. When I replaced mine, I never had to touch the distributor or anything to adjust timing, but once I put the new module in, timing was way off.
Old May 25, 2008 | 12:00 PM
raythenegr0's Avatar
Poor kid, no ruler
Got the same problem, my timing's retarded. And everyone sells their timing lights for like 40+ bucks around here. It sucks.
I think I may just try to do it by turning it without the light. Probably won't be helpful though. Good luck with your problem!
Old May 25, 2008 | 01:37 PM
seanzzy's Avatar
its 80 degree's off my autotech teacher checked it. were is the ignition module? and can you reposition the distributor w/o taking the oil pump out?
Old May 25, 2008 | 02:37 PM
The ignition module is on the side of the distributor. Should be a black box. Not real big. You should be able to take the dizzy out. Without messing with the oil pump. As long as you don't crank the engine with it out. You do that..and you will have to line everything back up again. Meaning...TDC and all of that fun stuff..
Old May 25, 2008 | 08:01 PM
Again I ask... HOW do you / does he know it's 80 degrees off??????? There's no markings on the crank plate for 80 degrees... I don't know of any timing guns w/ 80 degree advance settings....
Old May 25, 2008 | 11:07 PM
lww's Avatar
lww
Head Muckraker
I don't know what your Autotech teacher is using to check it, but Nismo is right, that's so far off, it wouldn't run at all.
You don't "adjust" the ignition module. It's good or it's bad. When it's bad, it can work intermittently, but there's no adjustment.
What experience does your autotech teacher have with Datsun's and fuel injection?
ThatDude114
Jun 15, 2014 08:43 AM
RonK
Feb 11, 2013 08:48 PM
mrprofile
Jun 25, 2010 11:23 PM
TeamRonin
Oct 6, 2009 10:24 PM
Bigboy
Jun 24, 2004 09:42 AM
