t3/t4
Old Aug 28, 2003 | 01:22 PM
I have heard that lots of people use that exact size of turbo for the L28T and they love it. There is a bit more lag, but not lots of lag. The boost levels, however, are tremendously higher. You can't do much with the stock turbo. 12psi so about 240-250hp max with a well worked engine.
Old Aug 29, 2003 | 02:53 PM
veyenyl's Avatar
It's still a t3 turbine wheel. Stock l28et uses a t3. I would say NO lag. That sucker will come on early and come on strong.
Old Sep 10, 2003 | 10:04 AM
Lazerus's Avatar
Lag should be virtually non existent, considering that a T3/4 hybrid of some sort is the turbo of choise for most streatable 4 bangers with less than 2L of displacement. And if you spend the extra money for a equal length turbo header and a nice mandrel bent exhaust then you should be just fine.
Old Sep 15, 2003 | 02:22 PM
lifegrddude's Avatar
Externally Wastegated
I'm using a Turbonetics t3/t04b turbo and it runs great. Lag isn't bad at all. Boost starts at about 2300rpms and max boost hits at 2800-3100 depending on what boost level I'm using. Anyway, just thought I'd chime in.
John 82ZXT
