supercharging an L28
Old Dec 30, 2003 | 06:55 AM
Lazerus's Avatar
IMO you would porobably get more go juice for you money with a turbo, but with that said as far as the intercooler and bov, you would only need those for higher boost applications. Are they good things to have, yes. Do you need them, no.
Hope that helps you a little, if you do this be sure to post plenty of pics, good luck.
-matt
Old Feb 22, 2004 | 12:40 PM
lifegrddude's Avatar
Externally Wastegated
Will the injectors work? I thought they were a different impedence than our system's. I think they flow about 270cc, but I'd have to go look through an old Option mag to find that and be sure. You'd be better off finding turbo Supra injectors as they flow a bunch and are low impedence like our OE ones.
John 82ZXT
Old Mar 21, 2004 | 01:38 PM
speedgato2's Avatar
Originally Posted by Arro
Umm, no offense, but anything over 7psi should be intercooled. Just because a few car companies in the 80s decided to run 10psi without them doesn't make it right.
Even my supercharged Corrado has an intercooler stock.
And BOVs help reduce lag time which for turbos is always a good thing. It also reduces the stress on the thrust bearing which for you guys with old turbochargers is a very very good thing.
And I do think that spending the effort to supercharge this thing is a waste when there's already a manifold and turbo setup that wil bolt right on (and is OEM). You might as well just swap in an L28ET and associated electronics.
so is what you're saying is that i could just bolt on the manifold and head (p90?) from a turbo. using the appropriate electonics and perifrials i could still use the block already in my '82 zx?
Old Mar 22, 2004 | 01:12 PM
Yes, but the non-turbo piston rings are thin and weaker. If you're going to swap 80% of the turbo engine, why not just include the trubo block? its better that way.
Sell the supercharger on eBay. Some ricer will buy it and not know what to do with it, but you'll have his money.
Old Mar 22, 2004 | 03:51 PM
smartman3000's Avatar
Supercharger is definately the way to go. Believe me, you won't need an on/off button as soon as you bolt that baby in, you'll want the power all the time! With 8.8:1 compression and aluminum heads, this setup is perfect for a super. The boost will always be there and turbo lag will be non-existent! This is going to be great for you. Only problem I see is manipulating the computer to do what you want it to do, which shouldn't bee too hard with these older computers. Use the supercharger and you can spank all those Hondas on the road out there
Brian
pabdosado
24
Apr 15, 2009 08:00 AM
michanic220
Jun 20, 2008 07:48 AM
bigkahoona101
Aug 19, 2002 01:54 PM
lysik
Jul 29, 2002 06:16 AM
