sputtering problem HELP
Old Jul 31, 2007 | 09:02 AM
BhamZ1982's Avatar
Ok so for a while i have had this sputtering problem like the car is going to die (but it never does) when i turn the ignition on and start driving it. It gets better as the engine warms up, but still continues to sputter like something isnt igniting right. I just purchased and installed new fuel injectors...can anyone help me?
Old Jul 31, 2007 | 09:07 AM
Is it running rich? Blowing smoke? Is it a turbo or n/a motor? Did the new injectors change anything?
Old Jul 31, 2007 | 10:08 AM
duowing's Avatar
NisTuner
Have you checked the ignition timing? Then I would say Cylinder Head Temp Sensor, and also check your Throttle Position Sensor. It could also be related to your Ignition Module, but start with the timing.
Old Jul 31, 2007 | 11:51 AM
yeah what they said, and also look for vacuume leaks maybe change your cap rotor and plugs and wires. you know a tune up. and yeah check that timing.
Old Aug 10, 2007 | 06:40 PM
misterzx90's Avatar
Talking
i had a 86 300zx and i had a similar problem and it was the o2 [oxygen] senser had it to 10 mech once it was replaced i had no problem hope yhi helps cheers
jsuarez5125
Apr 9, 2014 02:45 PM
91ztt09
Apr 20, 2013 04:00 PM
turboZdriver
Nov 14, 2011 08:10 PM
CWHammer
Jul 11, 2011 03:30 PM
Heat Rave R
Aug 31, 2007 12:28 AM
