Sometins up
Old Sep 6, 2004 | 01:19 AM
Skully's Avatar
Sometins up
so i go to visit my friend to next town its a 2 hour drive...
on the way there no problems...
on the way back ugh...half way trough.....
im driving in 5th round 3000 rpm and i feel the car hesitating...so i pull over to the next gas station and the car just boggs down n dies...i tried to start it it ran like at 200 rpm and BLACK smoke out the back and if i try to revv it just shakes and runs like crap! So i was like CRAP! So i played around with connections and spark plugs and cables and the AFM and after 2 hours of screwing around (didnt change any settings at all, just unpluged and pluged connections)...i try to start it and it started bit rough but then work itself in and ran perfect 800-900 rpm....so what the hell is up with that huh? one of "its" quirks!! where you call your brother and tell him your cars fuxed and hour later when he comes the cars damn fine...
Old Sep 6, 2004 | 02:04 AM
Las VegaZ's Avatar
I had things like that happen before, 20 year old cars are weird like that.
Old Sep 6, 2004 | 10:09 AM
duckyz's Avatar
Sounds like you knocked some carbon loose and the motor was choking on it for awhile. Mine does wierd things after I drive it a good distance too. I'ts not really used to anything more than my daily 8 mile commute.
Old Sep 7, 2004 | 01:43 AM
Skully's Avatar
i dunno guys gave me a real scare....
Old Sep 7, 2004 | 01:15 PM
For "fun" I once unplugged my head temp sensor to see what that does. Runs super rich and chokes and coughs. Can't hold an idle long. Maybe it was just a bad connection.
Old Sep 7, 2004 | 02:33 PM
Skully's Avatar
yeah could be i noticed connections are all oily
i have a damn oil leak somwhere and it hits the belt + the fan and SPRAYS all over...all the connections were oily i gotta fix that!!!!
what else do you do for fun??!
Old Sep 8, 2004 | 08:05 AM
I poke holes in the intake manifold gasket to see if it increases performance!
Actually, at the time I unplugged the head temp sensor I was trying to fix a rich mixture problem. I ended up replacing the head temp sensor ($50) but that wasn't the problem. It was the fuel pressure regulator. The one time I took my Z to a mechanic was that time. Cost me about $300 for that diagnostic.
Old Sep 8, 2004 | 10:58 AM
Skully's Avatar
HA HA HA real funny REAL funny!
you take your car to the mechanic?? im not asking YOU any more questions! :P
Old Sep 8, 2004 | 11:13 AM
Las VegaZ's Avatar
LOL
Old Sep 8, 2004 | 12:20 PM
Dont' worry, I get all my answers from my mechanic! You don't actually thing I know all this stuff???
Old Sep 12, 2004 | 10:48 PM
Skully's Avatar
hey well ask you mechanic whats goin on cuz it happened again...i ran fine till I slowed down for an accident and gave it gas n that was it stumbled..same symptoms as i mentioned before in my first post...now i cant get it started cuz my batts low...i tried turning it over...it turns then starts slowing down as battery almost dies...but then suddenly starts going as if it was gonna start...im bumed out ....i towed it to my garage n will work on it tomorow...any help appreciated
Old Sep 13, 2004 | 08:34 AM
Well, another long shot is that maybe your alternator or battery (connections) are bad. If you have weak spark I suppose it could run really rough and look rich because the fuel isn't burning well. Clean the battery connections. Take the battery out of the car and charge it. You do have a volt-meter so you should be able to see if you have an alternator charge.
Old Sep 13, 2004 | 08:54 AM
EZDUZIT's Avatar
East Coast Style
That is a good possibility, I was messing with my 78 this weekend and it would crank up fine and idle but after a little while it started running ruff I noticed my voltage light flickering and pulled another vehical over next to it. Hooked up the jumper cables and it instantly started running better. Thats pretty odd, put my meter on it and it read 9V, it should read 14V running.
Old Sep 13, 2004 | 01:29 PM
Skully's Avatar
yeah ill play around it maybe buy a new coil...
maybe it rattled something loose when i slowed down n went over the railroad tracks
thats when it started happening
Old Sep 13, 2004 | 07:49 PM
Skully's Avatar
well i pulled my plugs they were oily.....
i cleaned em and put em back in now i hafta charge my battery i tried starting it...felt like it was gonna go unlike before but batt died...ill try tonight
nope tried just turns over but nttin i pulled the plugs again n they were wet...
Old Sep 14, 2004 | 08:38 AM
So you're thinking you aren't getting spark anymore. When a coil goes out, it just suddenly dies and that's it. It won't stop and start or cause a bad idle. Its the ignition module on the distributor that "can" go out and come back to life for a while.
Old Sep 15, 2004 | 12:32 AM
Skully's Avatar
yes thats what i tought too....like the lil black box on the side?
well when it ran...i would disconect and connect the plug real quick before it died and it would revv up a lil then sputter back down...how can i check it that it works...i dunno wtf's goin on im scared
Old Sep 15, 2004 | 08:35 AM
My mechanic is out of ideas...
Old Sep 15, 2004 | 11:21 AM
Skully's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
first time iheard you say that...lol...
Old Sep 15, 2004 | 11:49 AM
Skully's Avatar
well its gettin spark...its gettin gas...it can turn over but wont start. last time it ran it ran around 200 rpm black smoke outback rough as hell....it suddenly did that after i went over some RR tracks...now i cant get it to start
is it maybe my timing....and why when i take the cap off the distributor and take the rotor off the little teeth (looks like a gear) dont line up with the posts on the side...im sure you know what im talkin about is it suppose to?
maybe i should check the gas agan...my guage isnt workin all that well..
Old Sep 15, 2004 | 03:45 PM
Dorifto's Avatar
I had this problem on an '85 Ford Escort today and - lucky for you - I know exactly the problem ... If your coil isn't putting out a spark, it's that ignition module. I took it to AutoZone, and they tested it on a special machine for FREE. They can tell you if it's bad. If it's not the iggy module, bring them the coil, they'll test it as well. Hope this helps guys ...
__________________
The RallyBeater has a turbo muffler!!
Old Sep 15, 2004 | 05:01 PM
Skully's Avatar
ok man cool ill go buy a new coil because i was gonna buy one anyways...and im gonna bring the ign coil to the local auto store...we have parts source...same stuff...canada...anyways hopefully its nothing bigger
Old Sep 16, 2004 | 03:02 PM
Skully's Avatar
HOLY MTHRFK!!!!!! 300 BUX FOR A FREAKIN LIL BOX OF ELECTRONICS!!!! im goin to the junkyard....i aint payin 300 bux for a ignition module....
Old Sep 16, 2004 | 03:35 PM
You can buy a nice parts car for $300
Old Sep 16, 2004 | 05:44 PM
Skully's Avatar
and have another junker laying around the house no thx plus theres not many Z's here as you think....if its not on the road its in the junkyard...and theres a few left on the road...ill go to junkyard and get a module if it works works...i hope its the module and nothing bigger....anyways if you gots more imput go hard
