Running rough
Old Dec 11, 2003 | 07:50 AM
Did your oxygen sensor get replaced? ...or maybe disconnected? Its close to the head pipe.
Even if something was clogging the exhaust like a bad catalytic converter, your idle should be fine. Its the midrange and high rpms that are affected there.
Try adjusting the ignition timing by hand slightly. Don't worry about if its set to factory specs. Retard it a little then try it, then advance it. Usually advancing it smooths out an idle and bring the idle speed up slightly. If you smooth it out, you can bring the idle speed back down with the adjustment near the throttle body.
The ignition timing I'm talking about is just losening that little bolt at the base of the distributor and turning the distributor by hand. Once its at a good spot, tighten that bolt up some. (not too much)
jjk_52
Mar 29, 2014 07:48 AM
steady88
Apr 23, 2013 08:29 AM
mikep
Sep 28, 2007 07:33 AM
tehweej
22
Jul 9, 2007 09:52 PM
91Zman
15
Oct 24, 2005 07:08 PM
