quick intake question
Hey, does anyone no it the N47 intake off a 280z will bolt up and work right on a P79 head on a 82 280zx? Everything like the egr and cold start valve work? or could i just just delete the egr?
thanks
thanks
Welcome to ZDriver!
All L24 through L28ET intake ports & studs are in the same location. So yes, you can use an N47 intake on a P79 head (which I believe some setups actually came from the factory like that).
The cold start isn't affected by the intake... it's controlled by the ecu. The EGR is controlled by vacuum.
