popping and sputting
my car was running great until i left it in bmore wit a friend... now it has a lack of power, it pops out of the intake and it like has this sputter/fluttery sound when you are reving or accelin... i thought it was cause one of my plugs has lost to lil screw on top piece, so i replace it.. the plugs, wires, cap rotor are all new..the air filter is new and its a CAI... i pulled it off and the car still did the same thing.. i checked the connections at my VAF and those were fine.. anybody have any suggestions.....
VAF vein(sp) air flow meter..... and i would hope he didnt... i was under there today and noticed some of my vac lines are spongy as hell and the vac line for the vac advance on the disty is all messed up, so i guess i really do just need to go in and replace all my vac lines.. i mean ill be at 200k in a few days anyhow
Originally Posted by drfrankenstein
what exactly is a CHTS.. also correct me if i am wrong but the ungly AFM with a flap door is called a vein air flow meter...
I've never heard the term "vein air flow meter" for the flap door AFM. There's a VPC (vein pressure converter)... but not a vein afm... I even googled it just to make sure.
so i was told my cam timing seems to be off by like a degree or 2... does that sound logical? my intake popping cause of the cam timing being off which i guess it does seem a lil logical since that would mean the valves arent opening at the right times
I'm having the same issues right now, along with the car dying if I let off the throttle. I thought I had it down to a timing issue as well, but after re-setting the timing at the crank and cam and playing with the dist. timing it seems to be not so.
Could be linked to the air regulator, or your mixture. Check the tips of your plugs to see if it is running very rich or lean.
the car is actually running rather lean... now i know i have never bothered the mixture.. the car run jus lovely until i left it in baltimore for a week... ill change the plugs and see whats up.. maybe i need to rebuild the AFM...
It's possible your distributor adjusting screw has come loose and has allowed the distributor to drift a few centimeters, which would advance/retard your timing slightly. That is what happens to my car when I push the dizzy advance a bit too far, it starts to pop and backfire with a slight miss in idle.
[QUOTE=NismoPick]
CHTS = cylinder head temp sensor. It's on the right rear of the head between spark plug 5 & 6.
i doubted nismo befroe and got proved wrong...lol that is where i would start since mine did the same till i replaced the chts
Sounds like mine...
There seems to be quite a few L28's with the same problem lately, I hope this group can come up with a solution soon, even the Nissan dealer can't figure it out, but then we are talking DEALER!
Here is one thing I recommend. Go to your autoparts store and get some seafoam. Run it through the vacuum lines. I don't know if this will work if you don't have an EGR valve, but anyway do it. It burns out as white smoke, so then that way you'll be able to see if you have any exhaust or intake leaks under your hood. I'm still not 100% positive if my leak was exhaust or intake related, but I know I have a pretty good leak going on and I've replaced damn near everything under my hood. Fuel Injectors, O2 Sensor, FPR, CHTS, TPS, AFM, Air Regulator, Ignition Coil, Ignition Module, Distributor, Cap, Rotor, Plug Wires, Plugs. I finally got my timing adjusted correctly, and re-adjusted my TPS to make it sure it was pretty much exact. All of this helped a great bit, but I couldn't figure out why my car was still running so awful until it warmed up. My guess is that the intake or exhaust manifold, whatever is leaking is leaking while cold, once it warms up the manifolds expand and close up the leak or at least almost get rid of the leak to the point that the car runs really good.
