Please Let Me Know
Old Oct 7, 2005 | 05:03 PM
280zExTURBO's Avatar
Please Let Me Know
DONT READ THIS AND GO ON IF YOU KNOW THE ANSWER PLEASE.
SOMEONE TELL ME, WILL A NON TURBO HEAD GO ON TO A TURBO HEAD IF THEY ARE BOTH 1983?
i HAVE A TURBO HEAD WITH BAD VALVES. I FOUND ANOTHER HEAD BUT ITS A N/A IS IT POSSIBLE FOR IT TO WORK?
LET ME KNOW WHAT I NEED TO DO.
Old Oct 8, 2005 | 02:07 PM
turbot5's Avatar
The answer is.....ggrrr hhuuhh....sorry I can't see a post go unanswered...while you wait for the right answer can you line up them? they should be the same.
Old Oct 8, 2005 | 05:13 PM
one is P80 and one it p79? or something. well they seemed to line up. i put the intake and exhaust to it. The on difference i saw was that the exhaust for turbo is square and the N/A is round.
Old Oct 8, 2005 | 08:11 PM
s/cL3.0's Avatar
Bleach is my Hero
DOHC 2heads stacked on top of each other j/k yes it will work you can put any L6 Head on any L6 block just compression will change .. Dont know if I personally go to N/A.. You can get P90 heads pretty cheap usually..
Old Oct 8, 2005 | 09:49 PM
I am putting a N/A head on a Turbo Block and i am still running the TURBO. thats the question, will it work?
Old Oct 8, 2005 | 10:24 PM
s/cL3.0's Avatar
Bleach is my Hero
Yeah it will but with Higher compression.. As long as the manifold fits over the ports..
Old Oct 8, 2005 | 11:34 PM
No, not higher compression.
The compression will be the same. Only difference is the exhaust ports. If you think you can get them to seal on the manifold, go for it.
Old Oct 9, 2005 | 01:11 PM
s/cL3.0's Avatar
Bleach is my Hero
huh?? So nissan changed the compression with the head gasket..
Old Oct 9, 2005 | 03:41 PM
dished or flat top pistons...
Old Oct 9, 2005 | 05:03 PM
s/cL3.0's Avatar
Bleach is my Hero
Oh thats right duh.. I just tore apart my N/A to that shoulda still been in there
