PLEASE HELP!! engine stalls on boost
Old Oct 8, 2006 | 06:40 PM
venom8343's Avatar
82 280ZX Turbo. My cousin had the car and the turbo started blowing oil out the exhaust but it ran like a bat out of hell. He parked it in Febuary. I bought the car 2 weeks ago. I put a brand new turbo on it and the when the damn thing hits 1 lb. of boost it just falls on its face and starts backfiring. I have done everything. If someone could help me please do. i would really appreciate it.
Old Oct 8, 2006 | 06:43 PM
that sounds definatly fuel related....
and what do you mean youve done everything...if you tell us what you have done so far we have a better idea on what to suggest...
Old Oct 8, 2006 | 06:49 PM
venom8343's Avatar
ok here goes. plugs, wires, cap, rotor, tried plug gaps starting at 50, 40, 35, 30, 25, now back on 30. fuel pump, filter, took off tubing going to and from the turbo to make sure no cracks or leaks, even put a couple of new clamps on. replaced all the vacuum lines. turned the fuel damper under the car up a little bit...
Old Oct 8, 2006 | 10:28 PM
nismo619's Avatar
fuel pressure regulator.. or make sure all your " new " turbo vacume hoses are on the right way..1 psi of pressure ? pcv valve might me cloged ? or EGR valve might be cloged...
Old Oct 8, 2006 | 10:56 PM
try the injector seals, they may be the leak, vaccum turns to boost leak
Old Oct 8, 2006 | 11:55 PM
entropy31's Avatar
The Cake Is A Lie!
sounds very similar to bleaches problem. i 2nd what shady said.
Old Oct 9, 2006 | 07:16 AM
^^^ 3rd.
Deffinate injector prob. If you pull the spark plugs & look @ the tips, you should be able to see which cylinder is having a problem.
Old Oct 9, 2006 | 04:33 PM
venom8343's Avatar
yeah a little oil did get in the intake tube leading to the throttle chamer. so the pcv could be stopped up. well the reason i dont think its injector seals is that the car ran perfect before that turbo started blowing oil. Then when i got the new turbo on it. it wouldnt crank for **** till i started running brake cleaner through it then it finally crank.
Old Oct 9, 2006 | 04:35 PM
venom8343's Avatar
all the plugs look the same. they even look a little lean.
Old Oct 9, 2006 | 08:38 PM
venom8343's Avatar
sprayed penetrating oil on ECU plugs and cleaned PCV. still does the same thing. what could be wrong with this car. it has got to be something simple! its driving me crazy
Old Oct 9, 2006 | 08:43 PM
it doesnt have to be very simple, and dont throw out the injector idea because it ran good 3 months ago or w.e. some cars ran great a day ago and then something with the injectors can go wrong...hey....all you can do is go downt eh list of all suspected problems eliminating them one by one....or take the fast way out and drop it at a shop that KNOWS Z's.....but thats last resort....
Old Oct 10, 2006 | 11:24 AM
re-tighten each hose clamp on all the rubber hoses on top of the intake manifold. Just a little though, you don't want to strip the clamp.
replace those injector o-rings that go where they seal against the intake manifold.
Old Oct 10, 2006 | 06:30 PM
jfairladyz's Avatar
Are you sure you got all the manifold bolts tightened down? Make sure all the bolts are tight and make sure anything bolted to the intake manifold (and could be a possible source of a leak) is nice and tight. Triple check that all hoses, including the intake hoses to and from the turbo in properly in place and tightened securely.
Old Oct 10, 2006 | 07:19 PM
venom8343's Avatar
ok i think its in the spark. I got out there tonight and ran the car some. When you rev it up the lights get dimmer. Arent they suppose to get brighter or at least stay the same. I think its losing power somehow and not letting the dizzy work like its suppose to. What about that? any suggestions
Old Oct 10, 2006 | 07:22 PM
jfairladyz's Avatar
It could be the alternator belt slipping when you rev the engine. That or it's possible the alternator isnt charging properly (from either a faulty alternator or just a bad connection somewhere). That would only explain the lighting issue though and wouldn't explain the boost problem.
Have you checked your timing? Whats it at?
Old Oct 10, 2006 | 08:21 PM
venom8343's Avatar
thats why that bastard is screaming. i checked the fan belt but didn't think about checking the alternator belt. Well if it isn't charging then the electronic dizzy won't work. right?
Old Oct 10, 2006 | 08:22 PM
venom8343's Avatar
no i haven't checked my timing.
Old Oct 10, 2006 | 08:28 PM
lww's Avatar
lww
Head Muckraker
No, the distributor will work as long as your battery is putting out at least 12v to charge the coil.
Old Oct 11, 2006 | 04:55 PM
venom8343's Avatar
well ladies and gentlemen i finally figured it out. it was the coil. auto zone gave me the wrong damn one. now she runs like a champ. i want to thank everybody for the help they have gave me.
Old Oct 11, 2006 | 04:58 PM
HAHA...no lie.....well thats good, man whoever first said its a fuel problem is a retard.....o, wait....
Old Oct 12, 2006 | 05:00 PM
venom8343's Avatar
lol. yeah no **** it was that ragedy *** coil from auto zone. hell i have been driving around in it all evening and very much enjoying it. now i move on to fix exhaust leaks and get that boost between 10 and 15. hehe. i got a mustang cobra convertible too. there is just something about that little turbo car that i love.
Old Oct 12, 2006 | 10:03 PM
thxone's Avatar
What coil did you finally settle with to make it work...I know the old school big, square, yellow, Accel super coil works very well on my N/A, so well in fact it burnt my coil wire and I couldn't start my car....now I have 7mm wires all around.
Old Oct 15, 2006 | 12:43 AM
venom8343's Avatar
i ordered one from O'Reily auto parts. i burnt me a mustangs *** up tonight by a car and a half. lol...that was funny as hell. it aint pushing but 6 lbs of boost right now. that **** is fisen to change
84z
Apr 12, 2014 06:50 PM
nerdbebo
May 22, 2008 11:45 AM
drisky
Oct 27, 2007 04:03 PM
crazywing99
May 3, 2004 02:46 AM
buffet33
Mar 22, 2002 04:11 PM
