Performance Engine
Old Sep 8, 2003 | 11:19 PM
icice9's Avatar
Super Siver & Black Stud
for the price of getting your head ported and polished and a new cam and maybe some headders you can get a whole L28 turbo engine and some extra cash to sepnd on upgrades... i know someone who spent over $1500 to get his n/a ported and polished and a lot of performance upgrades and IMO he will never have the HP potential if he gets a Turbo engine for his Z
Old Sep 9, 2003 | 11:41 AM
veyenyl's Avatar
Originally posted by 280zx Fever
Anyone can whack a turbo, fart can exhaust and a BOV and make there car fast. But, N/A thats where the tallent comes out..
That is a bunch of crap. It takes just as much knowlege and planning if not more to do a good turbo setup. Talent has nothing to do with it.
Choosing to go turbo or stay NA depends on the owner and what are the goals for the car. How much HP are you looking for? How much do you want to spend? Do you know enough about turbo engines to be comfortable with one? If you are looking for just a little more pep out of you engine there are the basic bolt ons. You can also raise the compression or put in a more agrressive cam and mess with the gearing a little but remember if you have an itchy right foot, the potential for more serious HP is limited unless you spend large amount of money.
If the number one goal is more HP, bottom line is who's faster
Old Sep 9, 2003 | 12:38 PM
Ya, and then the other guy says "Anyone can drop in a V8 and be fast" The corvette guys say "so what if you're faster than me, I've got a normally aspired engine and don't have to go turbo"
Bottom line still remains, whoever wins the race still wins. There's always a guy out there that'll look down on what you do and others that will praise you no matter what car you have or what you do to your car.
Yes, it is very true that a turbo is not the "easy route" In fact, most people dont' know enough about them to attempt to build a turbo engine or own a turbo Z so they stick with n/a. If all you do is slap on a turbo and BOV then you won' t have a good turbo engine. Normally aspired and turbo engines to be done well, are both done in slightly different ways to work with the different forces of air and fuel levels. Just like you can't build a really fast n/a engine and then years down the road put a turbo on the side of it...
Old Sep 9, 2003 | 01:53 PM
zpeedracer25's Avatar
LOL............veyenyl and Bleach I was thinking the exact same thing but you guys beat me to the punch!!!
Old Sep 9, 2003 | 03:07 PM
Skully's Avatar
suuuuure you were......
i say respect all who put in so much time and money into their car and are proud of it....respect the people who respect their cars....
Old Sep 9, 2003 | 03:37 PM
hehe
Old Sep 9, 2003 | 04:34 PM
veyenyl's Avatar
Old Sep 10, 2003 | 08:09 AM
I'd be curious to see if someone did a good complete performance upgrade on all the intake items first before doing the exhaust. Plus, focus on one system completely then move to the next. A mild cam is definatly a good idea, but will eat up half your money. You'll want all new rockers with that cam. Get the most mild one too, unless you raise your compression.
Old Sep 10, 2003 | 08:18 AM
Bleach is right, you don't want to do more then a mild cam. Depending on the age and miles on the engine too much of a cam is risky business...you could knock out the bottom end quick. I'd also suggest doing some general maintenance on the car if you've recently gotten it. Fresh fluids in the diff and tranny will free up some parasitic power loss. You guys should also do a decarbon treatment on the engine, especially if you want to put a cam in it. That will clean up the valves and the piston tops and get some of the power back. GM sells Top Engine Clean by the can and is very good for getting the carbon out. Buy a couple cans and follow the instructions on the can.
Old Sep 10, 2003 | 10:37 AM
veyenyl's Avatar
Bleach - I'm also curious to see what the results would be if someone upgraded one system at a time but I doubt that will ever happen. For under $1000, if your compression is still good fresh fluids and filters along with a good intake and exhaust system would be a good start. If you have money left over you can look into getting a mild cam.
If you dont want to go with a new cam you can also raise your compression. I'm assuming you have dished pistons. Swap your block with one with flat tops and you raise your CR to over 10. You can bring it back down a little with a thicker head gasket.
Old Sep 10, 2003 | 12:34 PM
hehe... tune-up in a can? I'm about to do a carbon removal, including a new timing chain. IE: I'm going to remove the head while I'm at it and really clean that sucker out.
A new chain advanced to #2 and no carbon ought to bring back a lot of torque to my engine. I hope it all works out like I think it will. When I did the block swap on my truck (L18) I removed just a tiny little bit of carbon from the valves. The engine had only 89K miles on it! I also advanced that timing chain, but I have a midrange cam in there (crane #2). It didn't bring in loads of torque (given its a 4-cyl anyway) but I could tell that at about 3,000 rpm the power came in faster and a little stronger than before when I had it at #1 position. On an L6 I'll probably notice the power at lower rpms better. (and with a stock cam) I'm not really into reving to 6,000 rpm anyway.
Old Sep 12, 2003 | 06:49 PM
duckyz's Avatar
Well, I'm keeping mine n/a.....just because (in my humble opinion) turbo engines are too high maintenance for my taste. Trust me, I own an '84ZXTAE. Much rather keep up with an n/a.
Easiest thing to do.....drop in a K&N ari filter. You alread have a cold air set up......no need to spend to many dollars there. Second---open up the exhaust. Go to 2.5"-3" with a high flo cat and a nice open muffler.
That should hold you for awhile..........'till the cam gets swapped, the injectors go to 500cc, the intake gets ported and polished....need I go on?
