P-90a head lash springs ?
Old Oct 19, 2006 | 06:29 PM
nismo619's Avatar
Hears the problem im coming across on my 1982 280zxt 2+2 it has the p-90a head right... and on the 1983 280zxt 2+2 has the p-90a head also..
But hears the big question when i took of the valve cover on the 82 and on the 83 i noticed somthing right away on my 82 it looks like there is 2 little springs on the valve guides ? lash springs ?
But on the 83 none of thouse springs are present ? do i need them on the 83 ? if there not on there will that cause a problem ? is that why the car will start but not gain any speed ?
Old Oct 19, 2006 | 08:27 PM
I thought only the 83's had the P90A... which would explain why your 82 & 83 look different...
Old Oct 20, 2006 | 01:54 PM
KTM200-280zxt's Avatar
Thats correct
Old Oct 20, 2006 | 08:19 PM
nismo619's Avatar
there are little springs on the 82 that are attached to the valves guids for the valves.. 82 is a p-90a
the 83 doesnt have these springs nor are they any were to be found.. 83 is a p90a head also.. hmm werid .. will post pictures monday...
Old Oct 20, 2006 | 08:38 PM
Well I know for a fact that a 82' has a P90 not P90a. Is it a late 82'? Does it actually say P90a on it???
Old Oct 20, 2006 | 08:41 PM
nismo619's Avatar
My 82 Is A 6th Month Of 82 I Can Take Pictures Tomorow When Im Off Word Around 3:00 ... When U Take Off Your Valve Cover Does Your Engine Have These Springs?
Old Oct 20, 2006 | 08:50 PM
RodMoyes's Avatar
Doesn't post much...
For Christs sake! ...
If it has adjustable valves, it's not a freaking P90A!
If it's an '82, It's not a freaking P90A
Get on with your life already.
Rod
P.S.
This is taken directly from the 280ZX Specifications thread:
CYLINDER HEAD
Datsun used 3 1/2 different head casting for the 280zx. I'll explain the half part.
I'll break it down by engine code:
N42: N47 (79-80) diamond exhaust ports with liners
F54: P79 (81-83 non turbo) round exhaust ports with liners
F54: P90 (81-82 turbo) square exhaust ports, no liners
F54: P90A (83 turbo) same as P90 but this head used hydraulic lifters.
All are aluminum non-crossflow design.
Valve Diameters: Intake:1.73" (44mm) Exhaust: 1.38" (35mm)
Valve Length (N47): Intake: 4.53" (115.2mm) Exhaust: 4.57" (116.0mm)
Valve Length (P79, P90/A): Intake: 4.45" (113.1mm) Exhaust: 4.48" (113.9mm)
Old Oct 22, 2006 | 02:37 PM
nismo619's Avatar
Hey ROD take a look at this item and tell me about thouse springs i see that are missing on the p-90a head of mine http://cgi.ebay.com/ebaymotors/NISSA...41266215QQrdZ1
aarang's Avatar
There are actually some P90a that have solid lifters. I think they were on the late '82s. I am positive they exsist, because I have one!! Not very common, though.
Aaron
Old Oct 22, 2006 | 03:29 PM
those springs are to keep the valve set in one place only, and that is against the cam to help prevent wear. the heads that require manual valve adjustment must have these springs, i dont know aboot the p90 head, maybe someone with some experience with that head will know
Old Oct 22, 2006 | 03:49 PM
nismo619's Avatar
Thankys shady 280zx finnaly some one helps me out.. Shady 280zx thanks man.. hey what would be the results if thouse werent there ? would the car start but have no power? by the way sorry i never told u this but your 280zxt looks awsome man.. maybe one day my 280zxt will look like that...
Old Oct 22, 2006 | 04:08 PM
not having the springs may wear the cam out a bit faster, cause the rocker would slap the cam instead of following.
Old Oct 23, 2006 | 07:29 AM
jfairladyz's Avatar
My '81 had a P90A. That P90A came out of my '82 parts car. I can only assume it came out of an '83 before that. Theres no chapter in the specifications book that says in the 20+ years these cars have been on the road nobody has swapped out the cylinder head on his '82.
But yes, ONLY the 1983 280zx Turbo came with the P90A from the factory. Atleast thats how it was is North America. I dont know how it worked in Japan or Europe.
ricksilvia
Mar 24, 2014 12:55 PM
immortal557
May 12, 2012 08:25 PM
country
Mar 23, 2011 09:32 AM
81 Black L28E
Jun 9, 2005 08:51 PM
81 Black L28E
Jan 13, 2005 07:25 AM
