Overheating....
Old Apr 29, 2013 | 07:42 AM
campfirestring's Avatar
Overheating....
So, after a long rain this weekend, and my car sat for about a day, I started it up and began driving about 20 miles back to my apartment. after roughly 5, this steam started pouring into my cabin, and i heard some sizzling behind my dash. I stupidly thought it was rainwater boiling back there, because my car is pretty leaky. it got more and more intense, and when i made it back to my apartment, i noticed my temp gauge had shot all the way up, and then POW! the cap blew off my reservoir tank and i had this little volcano on my hands. My radiator looks totally normal.
what's going on?
Old Apr 29, 2013 | 07:53 AM
I'd say the thermostat is stuck closed, or the radiator is blocked up, or the water pump isn't freely spinning (rusted up / loose fan belt).
Hopefully you didn't toast your head gasket.
Old Apr 29, 2013 | 07:57 AM
would blowing the HG be a result of the above things happening or a cause?
I'll check those.
Old Apr 29, 2013 | 08:06 AM
A blown head gasket can definitely make the coolant blow... but a blown head gasket is usually the result of a cooling system failure (on the n/a), or some monster cylinder detonation / misfiring.
I overheated my Geo Metro a few years back (Driving 80mph in 105*F with the a/c on ... for a 3cylinder that is absolutely maxed out). It started puking coolant out the over flow, and even after refilling it and changing the thermostat & cap, it would still throw coolant. It was a hole in the head gasket pushing the cylinder compression (air) into the cooling system until the weakest point would fail (plastic overflow cap).
Click for a good read: https://www.zdriver.com/forums/other...g-metro-29223/
BlueKitsune
Dec 5, 2010 02:42 PM
ZXT83
Apr 7, 2010 06:06 PM
my86z
Sep 16, 2006 08:41 AM
lillievickers
Sep 18, 2005 10:59 AM
Shameless
May 18, 2004 06:44 PM
