no spark from coil with pics <UPDATED CONT>
Old Sep 13, 2007 | 08:00 PM
intuitdriver's Avatar
UPDATED
SO i have power to fuel pump and it does it's thing for 5 seconds when the key is turned to run. I have power to ignition switch. The starter has power and turns the motor properly, and my noid light shows signal to injectors.
Im good to go except spark.
The coil gets power, but it shows power to both + and - and power won't come out the coil's snout. And obviously power is not present at the dizzy much less the spark plugs.
I have both the B/W wire from my NA harness and the B/W from my ignitor going to the + on the coil
I have both the BLUE NA wire and BLUE ignitor wires going to the - on the coil.
CONTINUED WITH PICS
Alright i have an idea i want to run by you guys: (This is not a pic of my engine bay)
I was thinking this little plug T connector that goes to the ignitor is the key to why i am not getting a signal from the coil to the dizzy. I think i have this plug in my car, i just don't think it is plugged into anything. because i have one of these 300zx ignitors
and i can't put that plug directly into it. SO i have mine hangin around loose and don't know if i should do something with itcan you guys make sense of this? Ideas?
82 zx -> zxt swap
i have an 82 zxt motor with all 82 zxt components (ignitor is 300zxt)
Old Sep 13, 2007 | 08:45 PM
Why are you using a 300zx ignitor?
Old Sep 13, 2007 | 08:46 PM
cause it was a cheaper replacement for me and plenty of guys have run it on the 280zxt and the 300zxt coil and ignitor throw crazy spark.
don't get me wrong, huge regret
Old Sep 13, 2007 | 08:49 PM
So, can you hook it up?
Old Sep 13, 2007 | 09:17 PM
yea its all hooked up, but the "t" connector doesn't hook up to it. Without the t connector hooked up, is that why the coil won't throw out its spark?
Old Sep 13, 2007 | 09:26 PM
How do all these other guys have it hooked up? I've personally never heard of using the Z31 ignitor for the 280zxt...
Old Sep 13, 2007 | 10:02 PM
i wish i knew.
you can see the "t" connector on there by the ignitor. I don't know exactly how to make that hook up to my 300zx coil in the picture... but i think that might be what is keeping the coil from getting the spark out
Old Sep 13, 2007 | 10:45 PM
thats the wiring diagram for the S30 turbo swap....
Old Sep 13, 2007 | 11:20 PM
yea i know, still, most of it works for my s130.... so... uh? about that t connector. Is it a problem?
Old Sep 13, 2007 | 11:35 PM
a connector style isnt going to stop a car from running, if you got it connected you got it connected.... it obviously wont plug straight in, but you can modify either the connector ont he car or the connector on the ignitor... your choice.
Old Sep 14, 2007 | 12:04 AM
see thats the thing, the ignitor looks as is in the picture. I dont know how to hook up the 2 wires from that connector, to the 3 available wires on the ignitor.
I broke the casing off the 300zx ignitor and put circle spades on the 3 wires to hook them to +/- and ground. The t connector... no idea how to splice that.
Old Sep 14, 2007 | 06:15 AM
oh jeez, i couldnt even tell there were three wires, i saw only two at first. dude, i would just get teh proper ignitor. otherwise find a write-up on zcar.com hybridz.org where people use these ignitors... but ive never heard of it either.
Old Sep 15, 2007 | 03:55 PM
i decided to just go pick up a 280zxt ignitor. this car is killin me =)
Old Sep 15, 2007 | 06:03 PM
Splendid idea. Tell us how it goes.
Edz280zx
Aug 22, 2008 05:22 AM
Edz280zx
May 20, 2007 10:31 AM
Milo (SZM mag)
Dec 29, 2006 09:26 PM
zpeedrazer
Feb 2, 2002 10:02 AM
Pats300zx
Oct 19, 2001 10:15 AM
