new ecu burned out ACC fusable link ?
why would a new ecu burn out the ACC fusable link cable ? im having to replace the fusable link right now... any helpful thoughts pleasE?
p.s. could the ecu numbers have a problem ?
bad grounds
bad ALT or volt reg in alt
not enuf grounds
just plan bad harness and wireing
something is over powering the system AND ECU
OLD CARS....I have had quite a few old cars going all the way back to 1960 impala.. everything before 77 SUCKS..pontiac's are even worse the list of most GM cars..THEY just fall apart in the electrial system wise.. to date I have owned aroud 55 car (I'm only 38)out of the GM one's I have had to replace or go in to great detail and repair in the wireing dept.
ITS JUST a fact old car bad wireing go hand in hand
AND THAT SUCKs BIGTIME
later
not enuf grounds
later
Also, If you blew the ACC link, it most likely wasnt your ECU since I'm pretty sure the ECU doesnt even turn on unless the key is in the IGN. position.
coreection it was the ign fusable link when u turn on the key all the dash light light up right ? well the old fusable link blew and when i say blew it was " exploded " out of the sheeth... too much power ? yall say ? so i up graded the fuseable link to a hier gauge.. what do yall think ?
bad idea. If you were blowing the stock gauge then a higher gauge just puts other components, like the ECU, at more risk to damage. The links are rated the way they are for a reason. It's the same reason you dont put a 20a fuse where a 5 amp belongs: protection. Find out why you blew the link in the first place and correct that problem. Dont bandaide it with a higher rated fuse link.
thetremendousti
Jun 22, 2009 11:00 AM
at-jefft
85
Oct 6, 2008 03:14 PM
raythenegr0
14
Apr 28, 2008 10:26 PM
