N/A to turbo conversion
Old Jun 21, 2003 | 04:15 PM
icice9's Avatar
Super Siver & Black Stud
well ill be doing the same swap by next year.. its pretty simple on the ZX.. the only problem i can see me having is the power steerting... i have the power asist steering not the rack and pinion... i know that if i dont change it its going to get in the way of the turbo..so i gotta get that replaced before i do it.. im also going to go with th t5 tranny that came with the turbo model.. its got a diffrent driveshaft too and yeah i gues ill be changing the rear diff too and half shafts... but the engine swap is pretty easy.. ive seen it done...
Old Jun 25, 2003 | 02:39 AM
Fredrik's Avatar
I solved the problem with the steering gear I just tilted the engine a little bit. And while i was at it I lowerd the engine a bit too.
Old Jul 2, 2003 | 07:35 PM
duckyz's Avatar
Ok....but what if I didn't do an engine swap? How difficult is it to install a turbo on an '83 ZX? I know the compression is low enough (8.3:1 if I remember correctly). What can the soock motor handle?
Old Jul 3, 2003 | 11:21 AM
The L28 with dished pistons from 1975-80 is 8.3 or 8.5:1 compression. The 1981-83 280zx has a different block, head, and flat top pistons. They claim 8.8:1 compression although it'll probably take boost just fine still. I'm not sure you would be best off doing that. The n/a rings are not nearly as strong as the rings on the turbo pistons. Keep it below 240hp; that's just a guess though. Maybe 8psi on a well built engine?
cerealkilla
Jan 11, 2004 03:27 PM
79GS130ZL
Oct 11, 2003 08:36 AM
79GS130ZL
Aug 30, 2003 12:24 PM
280 drooler
Jun 18, 2003 10:15 AM
Destrega
Jul 15, 2002 02:13 PM
