Max Boost
Old Sep 22, 2004 | 04:00 PM
81280zxtc's Avatar
Max Boost
Fellow Z buffs,
Just wondering if anyone knows what max boost psi would be for an L28 Turbo engine with a modified fuel system and T60-1 turbo, Haltech engine management.
If you need additional information on the set up, reply and I'll answer as best as I can.
Thanks.
Old Sep 22, 2004 | 10:34 PM
Las VegaZ's Avatar
My advice, start slowly and cautiosly. Try like 6-7 pounds first and work on the tune, then when you get that dialed in turn up the pressure slowly and re-tune.
Old Sep 23, 2004 | 10:27 AM
The factory head and block have been known to dyno at about 350 wheel horsepower before. Usually it is said to keep it at 300 or less with stock pistons. I believe that is around 18-20psi
But I don't know the details on that engine setup. That may require an aftermarket metal head gasket, and of course a large intercooler. You might want direct ignition (aftermarket ignition system) in addition to your fuel system. You basically need to keep your engine from pre-ignition or detonation and the higher the boost levels the more prone to detonation you get.
A lot of people run 12-15 psi with all factory equipment with only the addition of an intercooler, and have minimal problems.
VanBruno
Nov 2, 2014 10:16 PM
lilotanni
May 10, 2011 04:33 PM
1SIKZ
Mar 12, 2006 11:39 AM
jtmny1999
Apr 3, 2003 07:40 PM
DVSTT
Oct 18, 2001 06:09 PM
