Throttle Problems and more
Old Sep 25, 2004 | 01:08 PM
rifleman502's Avatar
allright, when im sitting at a stop sing (or any stop for that matter) if i stomp the gas pedal it kills the engine, just turns off.... sounds like a throttle position sensor to me, but itl only do it if the car is stopped, if its rollin down the road i can kick it in neutral and let it spin down, push it in gear and stomp it and it does fine, my brother says its loading up, but its fuel injected, so its not loading up, another question, where the hell is my horn relay located at, mine went out and according to the army, i cant drive it on post unless the horn works, so i gotta replace the horn relay and see if that fixes it, if not i gotta get a new horn... nother question, when i gear down and let off the clutch a little too fast, i hear somethin in the rear end go THUD! i dont know what it is, but im thinkin a U-Joint or sometin in the suspension...
i appreciat all the input i get, thanks
Zac
'83 280ZX N/A
Old Sep 25, 2004 | 04:02 PM
Skully's Avatar
klunk in rear end probably differential mount....could be bad u-joints too tho
horn relay is on the battery side theres a plastic cover somwheres there in the side....just unscrew the plastick and its in there...
tonsoffun300zx
Dec 30, 2011 09:25 AM
93300zx
Feb 9, 2010 10:31 AM
ZYAL8R
May 31, 2007 10:59 AM
Dutchrub03
Aug 8, 2004 11:45 AM
Tombarace14
Apr 5, 2002 01:21 PM
