Loss of compression
Old Apr 19, 2010 | 02:32 PM
Cali79zx's Avatar
Loss of compression
So I figured out my engine was 180 out. Prior to fixing it, I did a compression test. (Finger over the hole lol) individually and I had compression in all 6 cylinders. I had a relative come over and he took all 6 spark plugs out at the same time and there was no compression in any cylinder. Timed the engine correctly and then I had some compression in 3 through 6 but no compression in 1 or 2.
Took the head off and the pistons look like this
Thats the intake valve and its like that on every cylinder.
So why is only the intake valve hitting? The valves don't appear bent. I'm going to check that now. Just wanted to post this up first. If the valves are bent I'm just going to replace the head.
EDIT: The valves are not bent. Still have yet to figure out the sudden loss of compression.
90NA300ZX
12
Nov 16, 2005 07:52 PM
Brandar77
Oct 9, 2003 01:42 PM
duckyz
Dec 16, 2002 10:31 PM
kolts
Oct 26, 2002 06:36 PM
Zpeed
May 17, 2001 03:16 AM
