lightweight flywheel?
Old Feb 17, 2005 | 05:06 AM
nuzxowner's Avatar
would anyone recomend putting in an aluminum flywheel? is the gain in horsepower worth the cost, or trouble? i have to change out the clutch soon, so i was wondering if it is worth the expense. thanks
Old Feb 17, 2005 | 07:17 AM
DoTheDrew888's Avatar
I don't have any expirience with the lightened flywheel but $600 seems pretty steep if you ask me.
Old Feb 17, 2005 | 09:55 AM
lww's Avatar
lww
Head Muckraker
Depends on what you want to use your car for and how you plan to have it set up.
First, there is NO gain in horsepower. There is merely a reduction of parasitic drag on the drivetrain. What you will see is the engine revving a little more quickly.
Lightweight flywheel will let the engine rev faster and is usually a good option for a turbo setup.
However, it will also impact your launches since the rotating mass will be lower, you'll have a harder time keeping the engine at speed as you disengage the clutch from a standing start.
Auto crossers and road racers typically like the lightened flywheel because they aren't drag racing and they can accelerate a little faster out of the corners.
Drag racers want a heavier flywheel because they need the rotating mass to help put the power to the wheel for the launches.
Obviously, these are generalizations and contradictions will be found in abundance in full race setups in either vocation.
Daily driving, you want a heavier flywheel so you don't sound like speed racer at every stop sign in town. This is why OEM flywheels are typically heavier. Most 'average' drivers aren't subtle enough with a clutch to feather it properly in daily driving.
Old Feb 17, 2005 | 06:31 PM
nuzxowner's Avatar
thanks, you just answered my question. i dont plan on racing, just looking for a little extra kick out of first gear. my 83 zx is a little bit sluggish. thanks again
Old Feb 18, 2005 | 12:04 AM
lww's Avatar
lww
Head Muckraker
In that case, you'll probably be better off with intake, exhaust and fuel upgrades.
Enjoy!
Old Feb 18, 2005 | 09:26 AM
lightened flywheel won't give you added kick in 1st gear. If anything, less torque from a standing start. Get a 4.11 rear diff! That'll give you more torque.
ITSZX
Mar 2, 2015 08:00 AM
slownrusty
Apr 1, 2012 03:12 PM
Jared
FS: 300ZX (90-96)
Feb 8, 2010 06:18 PM
JPerkins
Sep 17, 2007 08:52 AM
RodMoyes
Apr 15, 2005 01:40 PM
