JUST wont START ... WHY? HELP !!
ok peeps its a 83ZX turbo.
I have put in a new puter, Fuel Injectors ,fuel filter , fuel pump, starter, coil, wires, plugs,.
NOW I am getting spark..
I have started to go threw the fuel system starting at the Fuel injectors back and it looks to me i am not getting enuf presser to the injectors..
could the tank be pluged.. or an I missing something.. I blew air back threw the line it seamed to blow something out "kinda" but I was not sure.. it still wont start..
this car have almost everything under the hood done and gone threw and I still have nothing...
WHAT THE F am i missing and I bet its something little that I missed HUH
or am I just bangin my HEAD on the WALL
HELP!!!!!!!!!
HELP!!!!!!!!!
air flow meter? causes big headaches on n/a's, and I am sure also on turbos
fuel pump relay?
what about your distributor? How old is it?
That's really all I can think of right now. Hopefully more people will help you out more.
fuel pump relay?
found it !!!!
I went threw from the injectors back .. spent 2 days wondering WTF is going on ... then the next day i checked the pump that was already out of the car and it worked??? what the hell it works????
SO I took the battery charger and went to the pump under the car.. had buddy start cranking on the engine and YAHOO first kick it was started!!!!
NO Power to the pump... now I feal like a dumb *** I should have checked it to begin with.. I guess age is creeping up LOL
NOW I have to trace it back to under the dash something is not hooked up..fuse blowen...computer switch...something little and it runs!!!!..
if all else failes run a wire to the pump and it can be a kill switch..
thanks all for the help... and I know this wont be the last of the Qs
moorebl
Apr 14, 2011 03:28 PM
