Just got 280ZX need help
Old Jun 6, 2007 | 04:31 PM
  #26
and then you can always go crazy and get ITB's and a standalone with a EDIS system.... lol....
Old Jun 7, 2007 | 01:36 PM
  #27
jochichuperman's Avatar
how do i know if my 280zx is fuel injected or carborated?
and can someone tell me the diffrence please? manuel doesnt seem to know
Old Jun 7, 2007 | 01:40 PM
  #28
um... you will see carburators or fuel injectors... that's how you tell. If you know anything about motors, it should be simple.
Old Jun 7, 2007 | 01:43 PM
  #29
oooo boy son, you got some learning to do.... google every question or go to howstuffworks.com and put in motor engine fuel injection carbueration, (etc.) and learn what makes a motor run.... you need it badly
Old Jun 7, 2007 | 01:44 PM
  #30
Pop the hood, look at the top of the engine. If you don't see anything hanging off the side of the intake. Mainly looking like 2 carbs, you have fuel injection. If you see 2 things hanging off, or if somebody put a 4 barrel on the engine. (Though highly unlikely) You would have a carbureted Z. I am pretty sure you have a fuel injected one. They started with stock injection, in '75, when the 280z was introduced.
You will see at the top of the intake, 6 long things in the engine. And with plugs on each one. Those are fuel injectors, sorry I can't describe things too well sometimes. lol But hopefully this helps you out.
Old Jun 7, 2007 | 02:02 PM
  #31
alright my z's fuel injected haha
and those cams are hella expensive
any cheaper ones?
and where can i get a 2 1/2" exhaust?
Old Jun 7, 2007 | 02:08 PM
  #32
From an exhaust shop...
Old Jun 7, 2007 | 02:23 PM
  #33
lifegrddude's Avatar
Externally Wastegated
Check out MSA for a 2 1/2 inch exhaust. Pretty cheap for their basic kit, and if you want more noise you can swap the muffler for whatever you want. Anyway, just remember, generally you can have 2 of the following 3:
-Cheap
-Fast
-Reliable
Old Jun 7, 2007 | 03:55 PM
  #34
jfairladyz's Avatar
All i can say for you jo is to read, read, read, read, read, read and then read some more. Hit up howstuffworks.com as was mentioned above for a basic rundown on how pretty much anything works. Get yourself familiar with automotive systems then put start wrenchin' on your car. You dont want to end up abondoning the project because you dove into it to quickly. I can tell you're seeking the knowledge because you're asking a lot of questions here. Another good reason to learn as much as you can about the mechanics of these cars is that they're pretty old and you're likely to be doing little things here and there and will be troubleshooting problems with some frequency. They're great cars though and worth the extra effort.
EDIT: and i'm not sure if you have one or not, but get yourself a Haynes manual from your local auto parts store. Depending on your area they may have to order it. It will pay for itself many times over (especially considering they're only like $15.00).
Old Jun 7, 2007 | 05:08 PM
  #35
cams from thezstore.com are VERY cheap, 179 and they are good cams, only thing that makes them expensive is if (and you should0 you get the cam kit which has new springs lash pads etc...
Old Jun 8, 2007 | 12:08 PM
  #36
i have the haynes manuel
and i bought na K&N air filter last night
my friends gonna make me an intake we're gonna work on it tomorrow afternoon
any suggestions on a home made intake?
Old Jun 8, 2007 | 12:58 PM
  #37
Don't use wood & hangers...
Old Jun 8, 2007 | 01:18 PM
  #38
lol, usually PVC will do ou just fine but it will look....... home made, lol. you can get bent metal for exhaust making for you intake from a pepboys or autozone
Old Jun 8, 2007 | 01:51 PM
  #39
oohh cool
i got my filter from Autozone so ill go back there
anyways u guys gotta check this out
http://videos.streetfire.net/hottest...67014d6311.htm
thats the url
Old Jun 8, 2007 | 02:05 PM
  #40
thxone's Avatar
Here is what I did, it is 3" PVC from Home Depot...plumbing department and it was less than $10 for all of the piping. It is a 90 degree pipe but you can get creative. The only problem I had was coupling the PVC to the rubber intake hose to the Throttle Body. I would definitely make a bracket to hold the air cleaner in place....not 16awg speaker wire like I did This is now on my Turbo car and I modified it to fit better...see pic.
The CAI on the Turbo
Old Jun 8, 2007 | 02:15 PM
  #41
sickk man thanks
exactly what ,me and my friend needed to see
awesome ill get the parts asap and post some pics
Old Jun 8, 2007 | 04:15 PM
  #42
jfairladyz's Avatar
looking at the price of JUST the cam is like buying new pistons & honing your cylinders, and then reusing your old worn rings: Just asking for trouble.
If its just a stock cam then you can reuse most of the valve train except for the rockers. But with a performance cam you then need to use new lash pads and possibly springs depending on the new cam specs.
Old Jun 8, 2007 | 04:23 PM
  #43
i know j i know, thats why got my parenthesis side not there. lol, and PVC..... mmmmmm..... yeah...... lol, uprade to something better lol it just seems so out of place.
Old Jun 8, 2007 | 05:19 PM
  #44
thxone's Avatar
It is cheap but effective...3" inner diameter, even in the bend = high flow, low turbulence. It may look ugly but it will work very well.
