Injector question.
Old Feb 10, 2005 | 01:00 PM
pinkneyss's Avatar
Injector question.
The injectors on my '80 280zx need tp be replaced.. Would it cause a problem if I replaced them with the turbo injectors? I'm not looking for a performance gain, I just found a really good deal on the turbo injectors.. I'm thinking that the o2 sensor will detect if the car is too rich & lean it out.. Am i right or will the car always run rich?
Old Feb 10, 2005 | 02:13 PM
The O2 sensor will compensate a small amount, but I've heard its not quite enough. It will run rich at lower rpms and midrange. If you modify your engine with a ported intake and really big cam, then at higher rpms where you might normally run lean, you'll be fine.
Turbo injectors in a NA engine is not usually wise.
soates4
Jan 20, 2014 10:26 AM
scoobydoo512
Nov 15, 2010 03:19 AM
DJAngelicon
Mar 14, 2010 07:55 AM
mrbillishome
Jan 4, 2009 09:12 PM
zbuilder
Jul 3, 2002 03:56 PM
