I need a New Clutch !!!!!! OMG !!!
Old May 18, 2006 | 06:54 PM
nismo619's Avatar
hey z people... im back im having a little bit of problems with my 280zxt when i stick it into first and drive its fine i romp on the gas and hit about 4,rpm and it slams out of gear.. i was told its the pressure disk.. what do yall think about this one ? http://cgi.ebay.com/ebaymotors/F1-RA...spagenameZWDVW
any help finding the right packadge will help me out alot thanks , ken
Old May 18, 2006 | 06:57 PM
icice9's Avatar
Super Siver & Black Stud
thats not a clutch problem..... that sounds more like a tranny problem.. when your clutch goes.. your car wont go.. even in gear...
Old May 18, 2006 | 07:00 PM
nismo619's Avatar
but thje pressrue plate can get worn right ? that would cause problems with the load.. when depressed ? am i right ?
Old May 18, 2006 | 07:13 PM
When the clutch is worn, it will just slip.... so you can rev the engine in gear, but it won't engage (or is slow to engage). When it pops out of gear, the syncros or actual gears are most likely worn to the point they don't grab anymore & it kicks back out of gear.
BTW... you can get a stock clutch from Autozone for $130 & it will grab just as good as that goofy "puck" style clutch.
Old May 18, 2006 | 07:24 PM
icice9's Avatar
your clutch will wear out way before your pressure plate does... but in your case.. NismoPick is dead on.. your syncros are prolly shot... thats why it pops out of gear
Old May 18, 2006 | 07:57 PM
nismo619's Avatar
how do i fix the syncros?
Old May 18, 2006 | 08:14 PM
Skully's Avatar
take it apart (the tranny)..buy new ones and put em in..put it back together...or get it rebuilt or another tranny...
Old May 18, 2006 | 08:16 PM
jfairladyz's Avatar
I dont know that that is something you want to tackle. Get it rebuilt, or better yet, find another used tranny. I'll parrot the fact that it has nothing to with the clutch
Old May 18, 2006 | 08:28 PM
Skully's Avatar
yeah i was gonna say that but didnt want to come off rude or anything...
look at a exploded view of our tranny..and if you go..."damn what the hell is that" then dont bother....its more complicated then just sliding **** on and off...its gotta be spaaced properly, aligned...lots work...
Old May 18, 2006 | 08:33 PM
LoL. Yep... why do you think transmission shops charge hundreds and even thousands to rebuild trannies??? It's not easy. The gears must be PRESSED on, and in the right order. Here's some spended views of the inside of the 5 speed tranny (not the Nissan one, but similar):
Old May 18, 2006 | 09:08 PM
nismo619's Avatar
i can do it !@ trust me !
Old May 18, 2006 | 09:40 PM
ok... go do it then! Tell us when you're finished & it's back together.
Old May 18, 2006 | 09:55 PM
do you have the proper bearing spliter, or removal tool, you cant use a gear puller on this tranny, ive taken them apart, and its not easy, im paying to have someone do my tranny next time, if its out of the car, then its aboot 700 buck to rebuild, and the syncro kit from nissan is 600 cdn, and then aboot 80 bucks a bearing, use nissan parts only, youll be sorry if you dont, trust me
Old May 18, 2006 | 11:06 PM
RodMoyes's Avatar
Doesn't post much...
That is EXACTLY what my tranny was doing... RIGHT BEFORE IT DISINTEGRATED!
Do yourself a favor, and find a "Donor" tranny from another Z. The parts alone to "rebuild" your current tranny, aside from being almost impossible to come by anymore, will cost you more than the car is worth.
Rod.
LikeZcars
Feb 24, 2013 06:41 PM
decalservice
Aug 26, 2012 12:16 AM
JSimpson
FS: 300ZX (90-96)
Jul 25, 2011 10:59 PM
z31_oldskol
Oct 9, 2005 03:11 PM
jtmny1999
Jan 18, 2004 09:04 PM
