How Much Clearance??
Old Dec 8, 2005 | 05:58 PM
I Bought A Strut Tower Brace From Msa. It Has Less Than 1/8" Clearance From My Fuel Rack.(more Like 1/16") Is That Normal Or Should I Tweek The Bar. Im Afraid Of It Hitting
Old Dec 8, 2005 | 07:31 PM
s/cL3.0's Avatar
Bleach is my Hero
I wouldnt worry about it too much..
Old Dec 8, 2005 | 10:29 PM
jfairladyz's Avatar
Make sure your motor mounts are in good shape Dont want that sucker torquing over into the bar. Just keep a fire extinguisher in your car and you can follow s/c's advice I'd personally make a little clearance if it's that close. Vibration alone can take up 1/16". Just take a dremel to the underside of the bar and shave another fraction of an inch out to be safe.
Old Dec 9, 2005 | 12:13 AM
Shady... post a couple pics of the setup (I'm all about the visuals )
Old Dec 9, 2005 | 05:18 PM
Ill Work On It, Tight Spot But I Should Be Able To Do It Once I Get The Cameras Program Loaded On This Thing
Old Dec 9, 2005 | 05:59 PM
Lost Vegaz's Avatar
start the car, rev it, does the motor hit? Or jack up the rear , use 2 jack stands, start and rev while watching. You might need another person. But that will atleast put the motor under some load. If it hits while doing that, then it will certainly hit while driving. Or a small piece of material that indents easily, tape it in between, go for a ride, and if you see a indent or crushed, then you know it hits.
Old Dec 10, 2005 | 08:11 AM
BJ BISIG's Avatar
Fuel Line Clearance
if you want to see if it will clear. have someone put the car in gear, foot on the brake and bring the rpm's up about 2500. the motor will twist on the mounts same as hard eceleration. if it does'nt hit then it prob won't while driving.
BJ
Old Dec 11, 2005 | 04:58 PM
I Went Out And Looked Now That The Suns Out. The Paint On My Rail Is Missing So I Guess It Hits
Old Dec 11, 2005 | 10:30 PM
Lost Vegaz's Avatar
Well, that is another way to find out. Way more simpler than any of the others.
Old Dec 12, 2005 | 04:47 PM
NOW ITS TIME TO MODIFY
zordietrying
Feb 28, 2010 02:17 PM
SHADY280
14
Nov 1, 2006 07:24 PM
preith
Dec 3, 2004 05:58 AM
toletero
Apr 11, 2002 09:25 PM
