how do i make it fast?!!!
Old Aug 18, 2009 | 05:37 PM
81-280zxnt's Avatar
Talking how do i make it fast?!!!
i recently picked up a 1981 280zx non-turbo.
doesnt really neeed anything.
im new to looking into performance things and this is my first nice/fun car.
what should i do under the hood that will give it more power?
ive just purchased some iridium sparkplugs. but other than that everything is original under the hood. i dont really want to put major things that require alot of tuning, and might kill it. I want stuff that will give it good power but also stay reliable.
the car only has 97000 original miles, has new oil and oil filter.
other than that, i dont really know alot about it, but i would love to learn.
any helpfull info u may know of would be greatly appreciated.
Old Aug 18, 2009 | 05:43 PM
DatsunKid's Avatar
Get outta my way.
Oh boy here we go again haha.
Save your money and buy a 280zx Turbo.
Old Aug 18, 2009 | 06:05 PM
81-280zxnt's Avatar
datsun are impossible to find in newengland...im lucky to come across one that i picked up with no rust and has good components.
any info on how i could make it perform extremely well, but stay reliable at the same time?...any info u got helps me.
thanks a bunch!!!!
Old Aug 18, 2009 | 06:27 PM
280zx2by2's Avatar
Haterade by da gallon!
hmmm how to make a 280zx fast...
step one, KILL IT WITH FIRE!
lol imo the cheapest way is engine swaps, either the l28et or the other plethora V8's and blaa blaa blaa
you will learn the pros and cons, alot of this depends on your mechanical skills
Old Aug 18, 2009 | 07:05 PM
skib's Avatar
This facepalm's for you!
heres my little diagram for ya....
[Power]-------|-------[Reliability]
the closer you get the red marker to one end, the farther you get from the other
If you want to make your NA fast, or even do a swap, its going to take real work and require tuning.
Old Aug 18, 2009 | 07:25 PM
280zx2by2's Avatar
^^^ assuming you want to stick with the stock engine... other wise the scale jumps to a higher scale or performance and reliability
lets get our x and y axis'ses right
.LS series Vates
. RB26
.[Power]-------|-------[Reliability]
. SR20
. stock L28
just my opinions, some may weight the benefits of an sr above a V8, but guys those aren't real men
Old Aug 18, 2009 | 07:47 PM
PurePontiacKid's Avatar
i felld offa mai trike
suspension mods are the best way to make a ZX faster.
Old Aug 18, 2009 | 07:58 PM
81-280zxnt's Avatar
thanks guys for your help, most of it makes sence so far...haha
Old Aug 18, 2009 | 08:05 PM
81-280zxnt's Avatar
how does modifiying suspension make a car faster?...not trying to be mean or anything....but how does that work?
Old Aug 18, 2009 | 08:16 PM
Read this book:
flatblack's Avatar
Oh... my... god...
Is this your first experience of the internet?
Old Aug 18, 2009 | 08:23 PM
81-280zxnt's Avatar
Originally Posted by flatblack
Oh... my... god...
no, im just trying to be polite. im also new to learning about working on cars, thats all.
Old Aug 18, 2009 | 08:25 PM
skib's Avatar
You can have all the HP in the world but if you cant hook up on a launch or take a good corner its not worth a ****.
Suspension is equally as important as engine work. Every part of the car works together to get the final result.
and that is a great book
Old Aug 18, 2009 | 08:29 PM
81-280zxnt's Avatar
alright thanks. apprciate it.
Old Aug 21, 2009 | 10:14 PM
pete8717's Avatar
Header, full exhaust, racing cam, triple carbs, electronic ignition = pretty quick NA. I'm keepin mine NA so I'm pretty much in the same boat as you.
Old Aug 22, 2009 | 04:17 AM
skib's Avatar
/\ head work
Old Aug 23, 2009 | 10:01 PM
pete8717's Avatar
I would also take the diff out of an 87-89 300ZX turbo for a cheap lsd but I would re-gear it to a 3:90. If I remember correctley those came stock with 3:70's. I hate open diffs. Also follow all of the machine work that that book suggests.
Old Aug 23, 2009 | 10:19 PM
Man... if $600-$900 is cheap for you, you must be a high roller!!!
Old Aug 24, 2009 | 09:26 AM
Captain caveman's Avatar
first you need spinners on your ride. your z will look fast even when you stop at a light, and if you go with the spinner hub caps and you can't find the right size you can always use zipties to jimmy rig it on your wheels.
Now buy some nitrous, it's probably the easiest way to add power to the car. You need a wet kit for the fuel injection system and I don't remember what people say the stock l28 can handle but it's a fairly tough motor.
Ok now to be on a serious note. Strip off as much weight as you can off the car. It's the cheapest way to gain more performance. It's free if you already own a ratchet set. You can also consider the nitrous option if you want.
Old Aug 24, 2009 | 09:31 AM
skib's Avatar
Originally Posted by Captain caveman
It's free if you already own a ratchet set and sawzall. You can also consider the nitrous option if you want.
fixed
Old Aug 24, 2009 | 09:45 AM
fixed
That's funny I was thinking about the hood on the zx. That thing weighs a ton and hacking up the ribbing underneath should shave a decent amount of weight. You would probably need some hoodpins afterward to hold it down well. Some people out there are weird about hoodpins though. oooh, and acrylic windows. The rear hatch uses a flat pane of glass. It would be easy to replace it with light acrylic. Someone told me they did that with their zx for drag racing.
Old Aug 24, 2009 | 09:51 AM
SpeciallySpiked's Avatar
I'm a Registered User!
We used 1/8" lexan for hte Volvo's windows. If you do anything thinner than 1/8" it'll break on you after good use. The Volvo's held up for all 4 years and it mostly held for the roll. Just be careful washing it, you can scratch it easily.
Old Aug 24, 2009 | 10:06 AM
lexan sounds pricey. How much would a sheet large enough for the rear hatch set you back on a zx you think?
Old Aug 24, 2009 | 11:21 AM
We bought ours from some local store for $160 for a 4'x8' sheet. I'm not sure if that was a good deal or not... But it replaced the entire rear window and both rear door windows on the Volvo with plenty to spare for other cars
Old Aug 26, 2009 | 03:03 PM
pete8717's Avatar
Dude I can get 3 R-200 LSD diffs right now for $150 apiece.
