hot or cold plugs
Old Oct 2, 2004 | 01:19 PM
roninjiro's Avatar
hot or cold plugs
when should i use a colder plug or when is a hotter plug needed?
Old Oct 4, 2004 | 09:08 AM
I don't know when a colder plug would be needed. I used a hotter spark plug once on a car with high miles that was burning a little oil. It would run good but then foul up the plugs every week. After running the hotter plugs, they didnt' foul up. That was a bad fix for an engine on its last leg...
Old Oct 5, 2004 | 04:29 AM
fenderbender02's Avatar
Has anyone ever used Denso plugs? I was told they were like NGK's and I was curious how they performed for anybody else. I tried to get the NGK's but they have to be ordered, hell they have to order the air filter. Any input would be helpful.
Old Oct 7, 2004 | 07:28 PM
mayitin's Avatar
plugs
In the older days we change heat ranges according to what the engine told you. one step at the time if plugs are black one step hoter if they are white one colder, but you must have all other things runing right such as carbs and f injection.If you have a stock motor put the ones call for.
Old Oct 7, 2004 | 10:38 PM
TheeZ's Avatar
Coming to understand "Z"
So im hopin this goes here...
Bout time for me to replace plugs.. Whats your favorite as far as brand and material goes?
Old Oct 8, 2004 | 06:02 AM
EZDUZIT's Avatar
East Coast Style
I run only NGK plugs in all of my Nissans and my Suzuki Samruai. However I am going to try a set of Denso Irridum plugs in my 300ZX Turbo. They Run theese plugs on just about every modified turbo car I've ever seen, From WRX's, Mustangs, Z's, Supra's, You name it . So I have to give them a try But to answer your question, don't waste your time or money for more expensive plugs IE(Bosch Platnium, AC Delco+4,Splitfire) I can't see any more performance or longer life from these over your standard issue NGK Plug. And just on a personal note I wouldn't put an AC Delco plug in my Lawn mower Thanks and hope this helps!
Old Oct 8, 2004 | 07:31 AM
Same here. I use NGK.
Stay away from Autolite.
Old Oct 8, 2004 | 03:38 PM
TheeZ's Avatar
alrite coo.. ive always used NGK just wasn't sure if ya guys had found anything new. ill stick with it thanks
Old Oct 9, 2004 | 05:18 AM
But you do recommend giving the Denso plugs a shot right?
Old Oct 9, 2004 | 06:41 PM
duckyz's Avatar
I have used Champion copper plugs (about $.49 each) and found that they perform about as well as anything on the market. The only problem I had was removing them. The ceramic isn't as strong as other brands. Each one had a crack or shattered when I changed them out.
This last time, NGK wasn't an option (parts store stopped carrying them for some reason....) so I went with the Bosh Platinum. Yeah..I know.... but they work well.
thxone
Dec 10, 2007 09:13 PM
91Zman
May 13, 2006 09:59 PM
justinmy300z
Jan 27, 2006 10:26 AM
Riz Z Speed
18
Aug 19, 2005 07:57 AM
