high rpm's
Old Oct 31, 2007 | 03:32 PM
82zxturbo's Avatar
high rpm's
my car has no power at 5000 and up, is that normal
Old Oct 31, 2007 | 03:34 PM
The L28ET makes it's peak hp in the 5k rpms... have you checked your timing?
Old Oct 31, 2007 | 03:36 PM
82zxturbo's Avatar
no, is there any timing advance plug anywhere?
Old Oct 31, 2007 | 03:43 PM
uh no... you use a timing gun and adjust it by turning the distributor.
Old Oct 31, 2007 | 03:46 PM
82zxturbo's Avatar
well i knew that, but i didnt know if it was like my truck, there is a plug under the dash and it drops the rpms, some emissions crap
Old Oct 31, 2007 | 04:46 PM
mostlikley the timing. does it start to hover around 5k or stall stumble sputter back fire anything? could also be leaning a bit other wise
Old Oct 31, 2007 | 05:58 PM
thxone's Avatar
Gotta be timing.
Old Oct 31, 2007 | 06:10 PM
doesnt gotta be anything. could be his imagination. doubt it though. but im saying. you cant just automatically rule it a timing issue. though it really does sound like one. could be the afm, could be injectors going out, could be in properly set tps, could be bad cap/rotor/wires/and or plugs. could be could be could be
Old Oct 31, 2007 | 10:48 PM
82zxturbo's Avatar
no, it doesnt sputter or anything, its crap taking off from a stop until boost, but its also auto, but 5 to 6000 it doesnt have any power at all
Old Oct 31, 2007 | 11:05 PM
still accelerates though right? as long as it does still accelerate then check the timing and might as well do a tune up new cap rotor plugs and wires run premium through it with seafoam in the gas and run some through the throttle body. doesnt really sound like you have much of a problem
Old Oct 31, 2007 | 11:11 PM
82zxturbo's Avatar
yes, still accelerates, i have done a tune up, i will check the timing... and i want a blow off valve, but i dont know how to install one, and i couldent find any threads, i know it goes on the j-pipe as close to the throttle body, but thats it
Old Nov 1, 2007 | 07:18 AM
Installation depends on which bov you get. Most have a flange that you can just weld onto the j-pipe. Others are connected via a hose to a port. On one of my 280zxt's I did this:
On my main Z I've tried a 1G DSM bov and a TurboXS/XSpower RFL bov:
Old Nov 1, 2007 | 09:21 AM
82zxturbo's Avatar
if i get the kind that just welds to the j-pipe is there any vacuum hoses that go anywhere or anything
Old Nov 1, 2007 | 09:24 AM
Yes, you need to take one vacuum line from the intake manifold to the bov to actuate it correctly.
Old Nov 1, 2007 | 10:28 AM
rfl is rice with its big ole horn to make a louder woosh hehehe... BOV installation once you get the flange on is easier than easy. if you cant achieve it in 2 minutes you shouldnt hold a tool. lol
Old Nov 1, 2007 | 10:57 AM
The ONLY reason to have a vented bov is to be heard... might as well make it as loud as possible.
Old Nov 1, 2007 | 01:15 PM
not on our cars. then its because we dont have a BOV any who and need one and its alot cheaper to just get a blow off valve and let it vent then buy the rest of the parts to make it recirculate. lol. i just dont like the RFL for some reason. id honestly rather spend similare money for the HKS the nicest BOV you can get at teh same price as the other guys or spend the extra 30 bucks or W/E it is and get tial, imo the best company out there for BOV's and wastegates. nothin wrong with your though nismo, i just felt like being fickle
Old Nov 1, 2007 | 06:05 PM
Spraguepsycho1's Avatar
Everything I've read says a BOV is pointless on a car with an auto transmission. Since you don't usually let off the throttle to shift an auto, the BOV never opens between shifts while accelerating. On some cars (mainly with Mass Air) a BOV vented to the atmosphere instead of recirculating actually hurts performance by causing a temporary rich condition because fuel has already been metered by the computer based on the air that was metered as it passed the throttle body.
Old Nov 1, 2007 | 06:32 PM
Yeah... not much need for a bov on an auto, unless you're always on & off the throttle.
zcarron
Dec 31, 2007 03:18 PM
hoov100
Feb 7, 2007 09:10 PM
El_Madmaster
Dec 15, 2004 06:02 PM
reyazul
Sep 8, 2002 03:06 PM
nissan1990
May 7, 2002 09:33 AM
