High Idle
Old Jan 6, 2012 | 10:57 PM
garretthes's Avatar
High Idle
I have read several posts on this but have not found help.
Basically my daughter's 79 is idling about 1800 when cold and hot.
I recently replaced the CHTS, the wiring harness attached to the CHTS, the plugs, the thermostat and air filter. I'm pretty sure there is NO vacuum leak. I replaced all the vac lines.
What to check?
Old Jan 7, 2012 | 10:01 AM
Supposing that ALL sensors are working correctly, I would check the TB stop screw. There's also a huge idle adjustment screw.
Old Feb 3, 2012 | 11:48 PM
garretthes's Avatar
Just to close this thread I should add the problem was the plenum wasn't installed properly at the throttle body and air was getting past.
Old Feb 4, 2012 | 09:17 PM
That would be the OTHER throttle body adjust screw - the one that holds it onto the plenum lol
madkiwi
Jun 6, 2015 07:40 AM
v0va
Feb 23, 2005 12:27 AM
rookey1
26
Mar 5, 2004 09:24 AM
pretender84
Oct 8, 2002 07:02 AM
DANZAMAN
Sep 22, 2002 09:11 PM
