Help In Jacksonville
Old Mar 4, 2010 | 09:24 AM
ITSZX's Avatar
Anybody know any good Z shops or mechanics in or around Jacksonville, Fl?
Having the same issues as the guys on the forums about the motor missing and I can't find anything.
Old Mar 4, 2010 | 09:31 AM
Thxone used to live in FL... though he doesn't check in much anymore. Hermultra also lives in FL.
I hope you mean the motor "has a miss", not that the motor is missing from the engine bay.
Lets start with: What have you checked?
Old Mar 4, 2010 | 02:08 PM
ITSZX's Avatar
Well, engine is still there!
Changed computer, distributor, AFM, plugs, Checked all grounds and made sure they were clean, checked fuel filter, fuel pressure is good. Checked for vacuum leaks, checked tps, good.
Interestingly, I ran it yesterday and then pulled the plugs, 6,5, and 4 looked really rich, 3,2, and 1 looked ok. How can that be. I mean I know the engine was running rough but really rich in 3 cylinders?? Again, really really rich.
Old Mar 4, 2010 | 03:28 PM
Is this a turbo or n/a motor?
The L28ET ecu plugs are prone to corrosion & becoming loose, which will cause all kinds of weird problems... I know from personal experience.
Have you also check the CHTS plug & each fuel injector & plug?
The CHTS will make the motor "wig out" if not working correctly. Also, if any of the injectors are clogged, leaking, or sticking, you'll have this type of problem.
Old Mar 4, 2010 | 05:53 PM
bojo68's Avatar
L28rt motors are sensitive to wiring?? I thought it was all jap cars...
Old Mar 4, 2010 | 08:21 PM
damn those l28rt motors!!! errrr, wait rt?
and another post by boho (on purpose) that's so damn helpful seein as he is an expert on anything if it is a car. DURRRR...
do what nismo suggested so far, it's a good start. and where is the miss? at idle or when accelerating at full throttle when you hit a certain RPM or all the time no matter what the car is doing?
Old Mar 5, 2010 | 05:48 AM
ITSZX's Avatar
it is a non turbo motor.
I changed the ecu so if there was a plug issue, think it would have showed then but will check for corrosion.
Have not checked each injector, will try that.
And hate to ask, what is CHTS?
Also, the miss is now at idle and all along the rev range.
Old Mar 6, 2010 | 10:55 PM
Cylinder Head Temperature Sensor. CHTS.
Old Mar 7, 2010 | 07:12 AM
ITSZX's Avatar
ok so I go to check the ecu plug, have some pins missing, according to the book I should be able to check #25, in my plug, it is not there. Can someone tell me if that is normall or did my pin back out of the plug??
bbnz
FS: 300ZX (90-96)
Sep 15, 2012 10:33 PM
AboostedG
Southeast Region
Jul 26, 2009 03:33 PM
