Hello, 1st post-trying to get the Z started
16 year old daughter bought a 79 coupe to restore. PO said it was running two years ago when the windows stopped working and he parked it.
Yeah right
So after fixing several wiring issues and replacing a leaking coil I still get no spark at the plugs. What should I check next?
Thanks!
Yeah right
Thanks!
are you getting voltage to the coil? Other things needed to check on the s130 are the fuel pressure at the rail. Vacuum. download the fsm from xenon website do google search you will find it. Read up on the beast. when you have some more data other than it doesn't start try another post with your results.
Inb4
Congrats on your daughters S130, can't begin to tell you how exited I was when I picked mine up =)
Yes I'm pretty sure there is no spark. I pulled several plug wires while starting and there was no spark arcing to the plug. No matter how close in I moved the wire it never arced. Should I put a meter on the wires?
That is if you know for sure your air and fuel system is working correctly.
My $00.02.
I removed the fuel return line, hit the starter and nothing came out. There was just a trace of fuel when I pulled it off. Something is NOT right. I wish there was a mechanic in Murfreesboro that could help me out for $$
Unfortunately I'm buy myself and it only gets power when the starter is running or the engine runs. I did finally notice some fuel coming out. It stinks too. I added 2 gallons of fresh fuel but it still smells like kerosene or something. May need to add more new gas.
The truck in my avatar is a 59 Apache Suburban.
Sounds like the injectors may be varnished over.
Throw a new fuel filter on it, and a 1/2 a can of Seafoam in the tank along with a few more gallons of new gas. Try and start it. The Seafoam will dissipate any water that condensed in the fuel tank and clean up the fuel system. It may smoke a little, but that's normal.
How old is the battery? You may need to change it out as well.
Just chipping away at the possibilities. I checked the EFI relay and it's working. I'm thinking the culprit is the ignition module. And I'm thinking about doing the upgrade I have read about using a different module and mounting it on the body.
The P-a-P in Birmingham has an '81 ZX in their yard... not sure if it's a turbo. I may be going down there this weekend to take a look at it.
All things aside, this 79 is a non-turbo, so we don't need to worry about "swapping turbo ecu's".I suggest checking the ignitor, ecu, and fuel pump.
Yeah right
Thanks!
Yeah right
Thanks!
It's possible to use the ECU from an '84 300ZX in a '79 turbo but it involves more than just swapping out the unit. Last I checked, there's an '84 at the Pull-a-Part in Nashville.
I'm not sure the ECU is even a problem as I'm not getting spark. The ECU wouldn't stop this unless I'm misreading the schematic.
