Fuel Sending Unit Problem
Old May 19, 2006 | 11:01 PM
BigEkak1941's Avatar
Does anybody have instructions/knowledge on testing the fuel sending unit in the gas tank? I removed the unit as it would show almost empty, but the gas tank was full. I don't know if it's the fuel sending unit or the gas gage in the dash. Any suggestions?
Old May 20, 2006 | 11:12 AM
jfairladyz's Avatar
First make sure there's no corrosion build up on the sender. If there is clean it up. Put the sender back in the car and first make sure it's gounded properly. If its still not working then try this: ground the Yellow and then the Yellow/Blue wire(not at the same time). If the needles deflects when you do this then the sender is bad. If the needle does not deflect then it's the gauge OR the wiring between the gauge and the sender. If you've got an ohmmeter then check for continuity between the ends of the sending unit wires to ensure there is no open circuit.
houlis1211
Feb 24, 2013 07:04 PM
HexaggramJDM
Jun 29, 2011 10:37 PM
rjc280z
Sep 29, 2009 01:13 PM
Carl's Z
Sep 12, 2005 04:53 PM
ratedZ
May 26, 2001 07:58 PM
