Fuel Pressure Regulator/ Flywheel
Old Jan 10, 2004 | 08:31 PM
240zprace's Avatar
to 1st question.... you need a rising rate fpr,so under higher boost you would increase fuel pressure.
2nd question..... use 225mm on 225mm set up only and 240mm on 240mm only. dont interchange.
Old Jan 12, 2004 | 08:21 AM
Why can't you interchange them? How about the larger diamter flywheel with the smaller pressure plate?
Old Jan 18, 2004 | 07:32 PM
FastZ's Avatar
I wouldn't see a problem with using the larger flywheel with the smaller clutch as long as the pressure plate bolted up. I would see a problem with using the smaller flywheel with the larger clutch being that the clutch would not mate properly with the flywheel.
Old Jan 19, 2004 | 08:36 AM
icice9's Avatar
Super Siver & Black Stud
the 225mm pressure plate will not bolt up to the 240mm flywheel... the dowl pins dont line up...
Gingie
Jan 21, 2014 05:40 PM
MistaZ31Turbo
Feb 26, 2009 08:24 PM
jtmny1999
Jan 9, 2004 09:44 PM
oakdalenewbies
Dec 5, 2003 09:16 AM
SwiggA88zxt
Jul 27, 2002 08:31 PM
