engine trouble/popping sound
Old Jul 11, 2007 | 03:52 PM
jo5h.ua_vx19's Avatar
There is a popping noise while the car is running, sounds like its coming from the mass air flow sensor.Idle around 500-600 rpms Car sat for a bit, recently did headers, plugs, and eliminated the cat and EGR. Can anyone help me out, let me know what you think.
Thanks a bunch.
jo5h.ua_V5x19
Old Jul 11, 2007 | 05:22 PM
thxone's Avatar
Thanks a bunch.
jo5h.ua_V5x19
Check to make sure your firing order is correct....doesn't cost anything to tripple check.
Old Jul 11, 2007 | 05:43 PM
and #1 is the front of the car..
Old Jul 11, 2007 | 07:15 PM
260zturbo's Avatar
Stupid Hurricanes...
15 to young 36 to old and 24 is just right....easy way to rember
Old Jul 12, 2007 | 10:48 PM
duowing's Avatar
NisTuner
Make sure your plug wires are in the correct order then grab a timing light and check your ignition timing, check all your vacuum lines for leaks, punctures, or anything of the sort, make sure your TPS is adjusted correctly. Then I'd say you could go ahead and test the AFM and the CHTS.
Jamie Q.
350Z Performance / Technical
Apr 7, 2011 03:32 PM
hobo105
Nov 9, 2007 02:57 PM
Jason C.
Aug 10, 2005 08:09 PM
zkyle
Jul 24, 2002 10:26 PM
zkyle
Feb 13, 2002 11:39 AM
