electrical woes
Old Aug 24, 2003 | 03:07 PM
icice9's Avatar
Super Siver & Black Stud
you might want to check to see if its yoru bat. it might not be holding its charge...
Old Aug 25, 2003 | 05:59 AM
cerealkilla's Avatar
Thumbs up
to me it sounds like either an alternator that is going bad or simply a loose charging wire. try this, start your car, let it idle far about a min. then disconnect the positive terminal from the battery. if the car stays running smooth, then your alt. is good.
if it runs any rougher or dies completely, then you need a new alternator. as far as the battery goes. if it is expired then chances are that you need one. also if you live in an area where the tempratures fluctuate from extremes, i.e. 30' to 90' in a short period of time this will kill your battery faster than the normal life of it.
Thumbs up
a280drvr
Apr 27, 2013 06:22 PM
BlueKitsune
Apr 25, 2013 07:28 PM
87pyro3
Apr 22, 2013 04:17 PM
HybridS130
16
Aug 18, 2006 09:09 PM
ShadyJ
Jul 16, 2005 10:17 PM
