Electrical issues.
Old Mar 22, 2013 | 02:44 PM
2E1X1Farmer's Avatar
Electrical issues.
So, my brilliant self left my lights on while I was out shooting for 4 hours. Needless to say when I got back to the Datsun, it was dead as can be. So I had my buddy try and jump my car off and about 15 seconds into it I see smoke coming from the fuse box next to the battery which I believe is where my EGI fuse is. The battery has quiet a bit of corrosion on it, so i'm not sure if that has anything to do with it, but when I looked in the box the EGI fuse/wire was burnt to a crisp and the wire seemed to be jerry rigged on there. It's a 82 280zx and i've had it for about 2 weeks, so i'm sure i'll find more things like that on the car. Any ideas from anyone? Obviously i'm going to replace the battery and i'm going to need to do something about that wire job. Any ideas would be greatly appreciated.
Thank you,
Dave.
Old Mar 22, 2013 | 04:43 PM
PredatorZ's Avatar
For starters
XenonS130 - S130 Reference
You can download the Factory Service Manual FSM at this site. It has a wire diagram and schematics. You most likely melted a Fusible Link, so you will need a replacement. Motorsport! Fusible Links & Covers - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
good luck and welcome to the forums
Old Mar 22, 2013 | 06:32 PM
Thank you very much!
Old Mar 22, 2013 | 08:05 PM
rogerz's Avatar
Grumpy & Helpful
did you get the polarity right when you jumped it. if not you may have fried the ecu. fix bitchin betty she will tell you when the lights are on!
Old Mar 23, 2013 | 05:45 AM
As long as the colors weren't lying I got it correct. :P
Old Mar 23, 2013 | 12:09 PM
PredatorZ's Avatar
Corrosion
Thinking about your first question, current will follow the path of least resistance. So if your terminal was so badly corroded that no current was getting to the battery, then the Fusible link heated up as the current had no where to go but the hot side of the circuit.
Dann Dunn
Aug 25, 2013 05:22 PM
Zcart
Mar 8, 2013 05:03 PM
87300ZZzz
Jan 23, 2013 06:55 PM
livinzlife
Jul 15, 2007 09:25 AM
