EGR pipe
Old Dec 18, 2012 | 08:38 AM
tamug92's Avatar
EGR pipe
Is there an aftermarket pre-formed EGR pipe (with fittings) available for use with a Pacesetter header? I have the 6 into 2 with EGR and O2 senser bungs. I would cut and modify the stock one but I dont have a flaring tool. What have others done?
83 280zx non turbo
Thanks
Old Dec 18, 2012 | 09:52 AM
Tried to hook it up - didn't work - cut it off.
Old Dec 18, 2012 | 10:15 AM
tamug92's Avatar
Gotcha. I read a post of yours from awhile back noting that you simply plugged the hole in your header and capped off the EGR. My first thought was to do this also. Is it as simple as that? I have been searching/reading all the other posts about deleting the EGR which has just confused me, mainly because they all seem to be about other cars/engines than the 280ZX.
on my 83' 280ZX non turbo I should be able to just do what you did, correct?
Thanks
BTW - I really appreciate all the stuff I find on this site, I have used a lot of the info I've found already. Im actually building a F rr i Daytona 365 GTS Kit on my 83' Zcar donor. On going project for last few years..
Old Dec 18, 2012 | 10:13 PM
Yea - the EGR is independant of the ECU so you're good to go other than an inspection that requires an operational EGR system...
Old Dec 19, 2012 | 06:14 AM
tamug92's Avatar
Cool thanks...
soysauce300zx
Jun 12, 2012 08:38 AM
Swahoozly
Apr 4, 2011 11:50 PM
n00blar
Jul 27, 2007 07:18 PM
robz32
12
Nov 19, 2006 05:26 PM
speedlimits
Jan 25, 2006 11:17 PM
