ecu rev limiter
Old Jul 10, 2008 | 08:18 PM
280zx2by2's Avatar
Haterade by da gallon!
ecu rev limiter
do the ecu's on these cars have rev limiters?
i just saw a guy on hybrid saying his stock ecu had a rev limiter
Old Jul 10, 2008 | 08:23 PM
ArmyZX's Avatar
From: Northampton, PA..Stationed in Fort Benning, GA
i always wondered that myself, but im pretty sure they dont
Old Jul 10, 2008 | 08:29 PM
The stock 280zx / 280zxt does NOT have a rev limiter. nuff sed.
Old Jul 10, 2008 | 08:31 PM
ArmyZX's Avatar
not quite enoughhhh, lol...is there a way to make one for it? just wondering...i love custom stuff
Old Jul 10, 2008 | 08:34 PM
Yep... buy an aftermarket ignition box like Mallory or MSD. Check my cardomain page.
Old Jul 11, 2008 | 05:52 AM
280zx2by2's Avatar
or you can go with bee R and get the nice popy sound!
originally posted by phil280zxt
Remember that you can not use an 81 turbo ecu on the 82/83 turbo's due to the external injector dropping resistors on the 81. The 82/83 turbo's have the resistors in the ecu.
I ran my original auto ecu on my 81 turbo for a while after swapping to a 5-speed tranny. The only noticeable difference was the rev drop off between shifts, but not a big deal. I also have heard that there is no rev limiter in the auto ecu's.
Old Jul 11, 2008 | 06:18 AM
(quote)Remember that you can not use an 81 turbo ecu on the 82/83 turbo's due to the external injector dropping resistors on the 81. The 82/83 turbo's have the resistors in the ecu.
I ran my original auto ecu on my 81 turbo for a while after swapping to a 5-speed tranny. The only noticeable difference was the rev drop off between shifts, but not a big deal. I also have heard that there is no rev limiter in the auto ecu's.(quote)
Huh? What's the point you are trying to make? And to quote someone you use [ quote ] .... [ / quote ]
Old Jul 11, 2008 | 09:22 AM
He said there is no rev limiter on the turbo auto ecu. That guy forgot to mention there is no rev limited on the manual transmission ECU and non-turbo ECU as well! Those ECUs are simple. They're like a small switchboard, not really a computer. A Nintendo is more complex than the 280ZX ecu.
The Z31 in 1984 was a big step up in ECU technology.
Shift at 5200 rpm. Its not hard to do. Your 280ZX revs so slow anyway.... all 135hp of it.
Old Jul 11, 2008 | 10:16 AM
280zx2by2's Avatar
so why does a game boy cost like $40 and a new ecu like $250
I HATE SUPPLY AND DEMAND!!!!!!!!!!
Old Jul 11, 2008 | 11:56 AM
People don't buy new ECUs. They buy them from a wrecking yard for $15 or eBay for $20-50.
Stay away from the Nissan Dealership for most items.
Why would you buy a Game Boy when you can play with aligators in Georgia?
Old Jul 11, 2008 | 12:04 PM
280zx2by2's Avatar
i was thinking blackdragon and actually dont have a game boy...
i do have a ps2!!!! now if i can only get a link to a thread on how to wire it up to the EFI system.... i could play madden and drive at the same time!!!!!!!!!!!!!!!
Old Jul 11, 2008 | 01:51 PM
lifegrddude's Avatar
Externally Wastegated
Yep, nothing but valve float at 6500 rpm. Not to mention the stock power curve sucks *****. No power after ~5600 rpm. Redline is pointless unless you upgrade the cam and breathing aspects of the motor.
Old Jul 11, 2008 | 02:06 PM
duowing's Avatar
NisTuner
That info about using the 81 ECU on an 82/83 car sounds incorrect. The Dropping resistors won't cause any issue, and as far as I'm aware there are no dropping resistors in the ECU. The difference in the rev drop off is related to the the fact that all 81' ECUs are from auto cars. I forget exactly why, but there was a slight difference that someone documented between the 5-speed and auto ecus.
As Bleach said the Z31 ECU/MAF combo was a huge leap forward for fuel injection. According to ZBum the Z31 ECUs have a 6000 RPM limiter or maybe it was 6500? I've never really tried for it. I just do like Nismo said and set up the mallory ignition's rev limiter to 6000.
Old Jul 11, 2008 | 02:46 PM
The dropping resistor is a real issue. Same thing is found on early and late Z31 injectors. Some are in the ECU vs at the injectors. I forgot all the details but my 1988 Z31 ECU needs resistors wired in for an L28 turbo setup.
Old Jul 11, 2008 | 03:44 PM
280zx2by2's Avatar
what are all of the advantages of doing the z31 ecu swap?
sence my car is a 81 doesnt that make it easier to do the swap cause of the one wire o2 sensor and i dont need resistors?
Old Jul 11, 2008 | 05:29 PM
duowing's Avatar
NisTuner
I didn't think the resistors were in the ECU and that was why when doing the swap to the 88-89 ECUs you had to wire in resistors. I thought they just used a different lower impedance injector? If they were in the ECU I'd think then we could just swap in the later ECU without resistors?
Advantages: Better Flow, Better Fuel Maps, Improved fuel efficiency, little more power, just runs overall better.
You don't need the resistors unless you're putting in the 88-89 ECU. The Z31 ECU will run just fine without the O2, probably just worse fuel economy. Although you will need to convert over to the 82-83 distributor that has the dizzy mounted crank angle sensor. There's a writeup on HybridZ where a guy walked through putting the swap into an 81.
Old Jul 12, 2008 | 04:49 PM
There are numerous writeups on the Z31 ECU swap. SEARCH
this forum as well as Hybridz.org
Most bennefits are found when running a forced induction engine.
Old Jul 12, 2008 | 05:19 PM
280zx2by2's Avatar
gosh!!! i was just asking..... BUUUUdEEEE
Old Jul 13, 2008 | 04:03 PM
Niku-Sama's Avatar
eff good grammar
what about a atari 2600 or something, is that a comparable swap for a 280zx ECU?
now back in the real world why are your guy's n/a's slow revving?
mine revs pretty fast
Old Jul 13, 2008 | 09:02 PM
Maybe you forgot to put it in gear?
Old Jul 13, 2008 | 09:19 PM
Niku-Sama's Avatar
eff good grammar
nope in gear
Old Jul 13, 2008 | 10:11 PM
lww's Avatar
lww
Head Muckraker
For a "measurement" that is absolutely and completely subjective, I find this part of the thread entertaining. I can tell you, compared to just about any motorcycle, the stock 280ZX revvs EXTREMELY slowly! Now, compared to a Ford Aspire, yeah, the stock 280ZX revvs like a raped ape!
Old Jul 13, 2008 | 11:20 PM
Drive a 350Z, then decide
Old Jul 14, 2008 | 09:52 PM
Niku-Sama's Avatar
eff good grammar
you also have to remember my other posts where 80Mph is about 4-4.5k aswell in 5th gear
Old Jul 15, 2008 | 08:22 AM
280zx2by2's Avatar
is quick rpm gain a direct corrilation to HP or is it more tward rotating mass?
