Distributor ?'s
Old Dec 16, 2005 | 02:19 PM
DODthunder's Avatar
Distributor ?'s
Will a non turbo distributor work in a turbo? and will different firing orders work? currently im running 142635. I read on one of the other posts thats its 153624. do they all work the same or is one better than the other?
Old Dec 16, 2005 | 06:03 PM
jfairladyz's Avatar
The distributor body is interchangeable but the internals and what not are NOT compatible between the two engines. They use two completely different means of crank angle sensing and also the turbo ECU controls timing advance/retard, where as the non turbo relies on vacuum and mechanicle means to do the same. So in short, your answer is NO.
Old Dec 16, 2005 | 06:53 PM
DODthunder's Avatar
thanks. then i have alot of n/a parts to get rid of
Old Jan 1, 2006 | 04:15 PM
TX_zx's Avatar
I saw your thread, Iam haveing dist. problems myself with my 83 280zx n/a. I got fire up into the cap but nothing out. Any suggestions ? or would you want to sell the dist you have ? This is driving me nuts.
Thanks
Zdon
Aug 12, 2013 03:01 PM
cpark_12
Feb 12, 2013 06:21 PM
Fast240Z
May 20, 2005 04:18 PM
xsciuga
May 17, 2005 07:11 PM
ZmeFly
Jun 3, 2001 12:04 AM
