damn alternators
Old Jun 6, 2005 | 03:04 AM
Captain caveman's Avatar
damn alternators
I've gone through 2 alternators on my 280zx. My damn car will only run off the battery. I don't know what is on the car that's sending these alternators to their graves. Does the 280zx have an external voltage regualtor that I'm unaware of or something?
Old Jun 6, 2005 | 08:33 AM
A lot of chain auto parts stores sell horrible rebuilt alternators. Some might not even really be rebuilt. They test them ok, so they clean them and paint them and sell them as rebuilt.
I bought a Bosch alternator after going through a couple at Shucks/Kragen. The Bosh one has already outlasted both previous alternators. I got mine from importedcarparts.com
Old Jun 6, 2005 | 03:35 PM
jfairladyz's Avatar
You could have a fault somewhere in your electrical system. A bad diode, bad ground, you could have some bad wiring thats causing the alternator to tax itself, etc.... Did you have the alternators tested to make sure they were bad?
Buy a new one if you can't find anything wrong with your electrical system. Don't get a rebuilt one, bad news just like Bleach said.
And no, there's no external voltage regulator, it's in the alternator. Is your battery in good shape? A bad battery can kill an alternator in no time flat.
Old Jun 8, 2005 | 02:05 AM
I have a new battery. Now let me ask about hooking up the alternator. does the positive wire go on the peg that says bat and the ground cable go on any other peg? I'm wondering, could I just bypass all the old wiring and run new wiring direct from the alternator to the battey?
The first alternator I did have tested and it came dead. I pulled it to and this is what it looked like
http://www.geocities.com/captain_cav...f/DSC00401.JPG
That peg turned out all corroded and destroyed. I was able to chip away pieces of the the nut. I'm not sure why that happened. That alternator doesn't even match the alternator that went on my car originaly. I looked in a haynes and that alternator was made for the 81 and up. I would think they're interchangeable though.
Old Jun 8, 2005 | 07:49 AM
Yup, power goes to BAT, the other peg is ground. You don't have to hook up the ground, but its a good idea.
I would leave the original setup in place as it goes right to the fuse panel. Run a second power wire from the BAT to your battery. Keep in mind that is an unfused wire and it is probably pretty big. You might want to run a fusable link or large capacity inline fuse on that line just in case.
Old Jun 8, 2005 | 09:01 AM
oh, ok. Could a bad fuse be the cause of my problem, because my fuseable links are in **** poor condition. I know if I just wiggle the fuse for my accessories stuff in the car will go on and off
Old Jun 8, 2005 | 09:44 AM
Bad or weak connections can cause low voltage problems. It is possible.
Old Jun 8, 2005 | 12:44 PM
Yeah it does sound like it. I had that problem with both of my Z's. I just replaced the fusible links. And if you just want to fix it. And not spend money at the dealer. Get either Chrysler or Ford fusible links. I have before, until I got the originals again! And they worked fine, just had to change the connectors, no big deal.
Old Jun 8, 2005 | 01:49 PM
jfairladyz's Avatar
If you have a multimeter you can check the resistance in your wiring from the alternator and the resistance in your fusible links to determine where your problem is. And unless the pre 81 cars had external regulators(I don't know, mines an 81), the later alternators should still be compatible.
Old Jun 8, 2005 | 02:28 PM
I think from 1977+ all Datsun cars and trucks had internally regulated alternators. Maybe 1978
All 280ZX's use internally regulated alternators.
Old Jun 8, 2005 | 03:17 PM
jfairladyz's Avatar
It's like a living, breathing Z reference library. I have a tuff time remembering my birthday!
Old Jun 9, 2005 | 10:56 AM
dang, These fusible links suck. Gonna cost lik $50 to get new ones from a dealership. Are there any kits or something to get rid of these fusible links and upgrade to something better
Old Jun 9, 2005 | 12:01 PM
assimilated420's Avatar
Chewievette is tearing his 79' myabe he can help ya... https://www.zdriver.com/forum/showth...4215#post74215
Old Jun 15, 2005 | 03:46 AM
Carl's Z's Avatar
Speak of the devil, I just changed mine today after just 3 years. Oh, well...
Old Jun 15, 2005 | 03:51 AM
Yeah well at least yo won't have to worry about it for a while! And you can't beat the lifetime warranty!
JewFro297
May 24, 2014 01:19 PM
silverzxbullet
Dec 26, 2013 05:37 PM
nismo619
Jul 27, 2008 07:18 PM
hoov100
Oct 11, 2006 09:49 PM
240z
May 30, 2001 09:50 PM
