clutch, shifter, or tranny?
Old May 13, 2010 | 09:42 AM
lovemyz's Avatar
1981 280zx 2+2. Iwas on the forum a few weeks ago looking for info on a problem having to do with not being able to shift into reverse without grinding and it was hard to shift into 1st. I changed the slave cylinder and master cylinder. Problem is gone for a few days; now it is slowly coming back any answers?
Old May 13, 2010 | 09:57 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Possibly still air in the system, bad hose, or the syncro's are going out?
Old May 13, 2010 | 01:47 PM
nismo619's Avatar
Throw out bearing ?
Old May 13, 2010 | 04:44 PM
^ I second that. Is it making any kind of noise while in neutral? Also you could have a clutch disk worn also. Happened to me before. Actually it had a couple of the springs broken off. And then it destroyed my throwout bearing. What a mess that was.
Old May 17, 2010 | 10:42 PM
daddiodanger's Avatar
second on the bleeding. quick and easy.
sometimes you need to rev the motor a bit when shifting into reverse.
It would be a good idea to make sure you have enough oil in the tranny. while you have the car on jacks you might as well change the oil and add a gear oil additive.
Old May 17, 2010 | 10:58 PM
BlueKitsune's Avatar
Intrawebz Wizard
I always shift into 5th then R on and manual car w/o letting up on the clutch till im in R never ground once for me lol
NuBeeZee
Jun 2, 2014 08:50 PM
Moy12
May 10, 2011 03:09 PM
Jared
Jan 5, 2010 06:39 PM
luckyZ13
Dec 9, 2009 02:09 PM
71240z
350Z Performance / Technical
Aug 13, 2007 06:57 AM
