chevy small block swap
Old Nov 5, 2003 | 03:30 AM
spdsk8r's Avatar
I am 2/3 the way through my conversion. The engine/transmission are mounted and wired. Just need cooling, driveshaft, and exhaust to complete.
Old Nov 6, 2003 | 08:53 AM
spdsk8r's Avatar
For motor mounts I used late 60's/ early 70's chevy truck motor mounts, as in the JTR manual. I made spacers to go between the motor mounts and the engine block; 1.38" thick on passenger side and 2.75" on drivers side. The chevy truck motor mounts then bolt up to the Datsun crossmember. Quite simple, really.
Old Nov 7, 2003 | 07:35 AM
spdsk8r's Avatar
Pete,
The motor is a 91 350 truck motor from a Chevy G-30 one ton van. The engine is rebuilt, stock compression. The heads are "cleaned up" stock 194's with dual springs. It has a Performer intake with a Holley 600 double pump carb. The cam specs are 488/510 lift and 295/305 dur. hydraulic. Power is running through a performance rebuilt 700R4 with a 2200 stall converter into a single leg R-200 with 3.70 gears. Exhaust will be dual 2 1/4" to single 3" through a Flowmaster dual chamber muffler to back of car. GM manifolds are being used, due to stearing box. Ramshorn on passenger side and manifold casting number 364747 on the drivers side. This manifold has a notch that clears the stearing box. In the future I plan on fabricating a custom header to fit around the box.and use a block hugger on the passenger side.
Old Dec 26, 2004 | 11:19 PM
B1nAryVilE's Avatar
hey rick have you ever considered this i mean it cost a pretty nickle but if you duplicate their similar method wouldn't that be a beauty =0) http://www.bankspower.com/twin-turbo-products.cfm
-chuck
Old Dec 29, 2004 | 05:04 PM
DoTheDrew888's Avatar
I've been considering doing a Banks TT SBC 350 swap for a while now. Man, that would be freaking insane. Just a matter of money though.
Old Dec 30, 2004 | 01:26 AM
B1nAryVilE's Avatar
hahahah you got that right "very large amount of money" sounds cheap for some reason and that would be such a lie. :-[...
-chuck
Old Dec 31, 2004 | 03:14 PM
ZedZilla's Avatar
Check out this site for a V8 conversion Kit
http://www.johnscars.com/zcar/zcar.htm
might be something of interest...
73Dat5unZ
Oct 29, 2012 11:10 AM
nick's81240zx
Aug 4, 2006 08:32 AM
ZDriver85
May 27, 2005 12:11 AM
MakoLS1
Mar 22, 2005 05:41 AM
Castorall
Apr 3, 2002 09:01 PM
