Car revs to 2k then drops to 100 then back to idle.
Old Jan 11, 2008 | 04:42 PM
2.8.0.Z.X's Avatar
Hey all,
If I rev to over 2k it cuts out and drops down to near death and then (sometimes) returns to 900 idle. It also takes a few tries to get it started.
It just started doing this and isn't drivable because of it. Last week it cut out a couple times but drove fine afterwards.
I'm guessing this is an ignition system problem. Could it be anything to do with my fuel pump/filter?
What are my best bets to check?
Thanks for any info.
Old Jan 11, 2008 | 04:45 PM
air flow meter's about to die, replace it and come back.
Old Jan 11, 2008 | 04:55 PM
2.8.0.Z.X's Avatar
Is there any way to check the afm without replacing it? I wan't to make sure thta's the problemo before replacing it.
read the stickies..
Old Jan 11, 2008 | 05:13 PM
Niku-Sama's Avatar
eff good grammar
my car did this, adjust the idle speed closer to arround 1k and see what happens.
i dont know what the nominal idle speed is in this car but it fixed my rev problem
Old Jan 12, 2008 | 04:27 AM
duowing's Avatar
NisTuner
according to FSM idle speed is 700 RPM + or - 100 RPM
Haynes I believe says 750 RPM + or - 100 RPM
But generally around 700-800 is the normal idle
Old Jan 12, 2008 | 10:21 AM
RodMoyes's Avatar
Doesn't post much...
Your TPS (Throttle Position Switch) is wet... This is the MOST common 280ZX issue in history and has been covered well here. the "Search" feature is your friend.
Remove the plug from the top of the TPS and dry out the contacts on the TPS and the plug (Compressed air works great if you have some.) Spraying electrical contact cleaner is a good idea also.
This usually happens after:
A: Getting the bright idea to wash your motor and engine compartment.
or
B: Leaving the hood up before it rains...
Rod.
Old Jan 12, 2008 | 10:51 AM
yeah ^^^ that or the AFM connector. both will cause this problem.
Old Jan 12, 2008 | 01:10 PM
Niku-Sama's Avatar
eff good grammar
hrmm, if my idle speed is 1000 my air regulator isnt working then, because come to think of it its always 1000!
now i have dropped the idle speed to 800 when its warm and it doesent dip...hrmm regulator's are expencive
Old Jan 12, 2008 | 01:27 PM
i got like... 2 extra lying around... air regulators.... if your interested.
Old Jan 12, 2008 | 01:28 PM
Niku-Sama's Avatar
eff good grammar
lemme poke at mine and make sure its truly ded then i'll let you know
Old Jan 12, 2008 | 07:06 PM
Niku-Sama's Avatar
eff good grammar
ok so when it was cold i wacked it with a screw driver and the RPM went up a little but but i was un able to adjust the idle speed, then when it warmed up the idle speed went even further up so i adjusted it down to about 725RPM, that was at about 3pm, i drove arround town untill about 4:30 pm i went to check it and it kinda dips a little but its at 725 rpm still but it wasnt completely cold.
when its cold when i move the adjustment screw the idle shouldnt change right?
Old Jan 12, 2008 | 07:15 PM
it will always change if everything is hooked up right.
Old Jan 12, 2008 | 07:27 PM
Niku-Sama's Avatar
eff good grammar
eh, i'll check it out later tonite and see, i may need to pop it off and hose some WD-40 in there or something.
300zx/maximas have a similar device only when its cold you cant adjust the idle speed very much, alot of turning only gains or loses a few RPMs but theres a way to fix them when they go bad:
http://www.cardomain.com/ride/309614
some one mensioned some place else new reg's have an adjutment screw, was that 280's or 300's?
Old Jan 12, 2008 | 09:22 PM
2.8.0.Z.X's Avatar
Yep -- was the afm
Cleaned it out and moved the circuitboard up a bit and now the car runs 20000% better!
While it was off I noticed a **** load of gunk inside the intake manifold -- what's the best way to clean it up a bit without pulling it off? (all my vacuum lines will die if touched)
Old Jan 12, 2008 | 09:33 PM
run carb cleaner and seafoam through it at the opening (infront of the TB) and through some vacumme lines.
oh... and... I WIN!?!??? i think? did i wind this time guys?
Old Jan 12, 2008 | 09:42 PM
no i won..................again
Old Jan 12, 2008 | 09:53 PM
no you said replace it. i dont think you can take the glory this time....
Old Jan 12, 2008 | 11:06 PM
Niku-Sama's Avatar
eff good grammar
alright i am stumped, the car is supposed to run a little higer rpm untill it reaces X degrees and then its supposed to drop to ~750rpm right?
or does ti run at X ammount of RPM all the time hot or cold?
Old Jan 12, 2008 | 11:19 PM
NA's have a cold start valve, not a fast idle like the turbo cars.
Old Jan 12, 2008 | 11:23 PM
Niku-Sama's Avatar
eff good grammar
oh ok, i was thinkin it idles up untill warm and then dropped, my haye says it does but then again theres its been fixed and ammended more than once.
so funky regulator thing same idle hot and cold, cold start valve
these cold start valves would be good for potato cannons!
forza time
Old Jan 13, 2008 | 12:22 AM
replace it, rebuild it, it all had the same outcome.
Old Jan 13, 2008 | 11:05 AM
lol ^^^^
w/e. cleaned it though fyi
Old Jan 13, 2008 | 05:22 PM
Niku-Sama's Avatar
eff good grammar
ok so i poked, the flappy thingy inside was sticking when it would get hot and not move so i poked and wiggled and hosed it with WD-40 and it seems to be good now. i bent the tabs on the connector to get a better connection but i have yet to find any crusty green connections.
my idle isnt steady any more but mabe now that something workin its time to re adjust or something else needs poking
Athrun
Feb 27, 2014 01:48 AM
sdkid123
Mar 7, 2011 04:59 PM
davedsz
Jan 6, 2010 08:55 AM
scorpionp54
Dec 26, 2007 11:26 PM
beez
Dec 23, 2004 08:20 AM
