Can someone identify this wire?
Old Jun 23, 2014 | 10:49 AM
GNRick's Avatar
Opened ecm kick panel on 1982 280zxt and found a green wire/black wire with a white plug on the end not connected. Can anybody tell me where it goes? Thanks.
Old Jun 23, 2014 | 11:31 AM
PredatorZ's Avatar
Unused
It shows it on the EFI turbo harness as an unused plug. Found it in the Turbo PDF page 1 / 5. No other reference to it (that I could find in a quick search), most likely a factory test point.
Old Jun 23, 2014 | 12:59 PM
GNRick's Avatar
Thanks! I was trying to diagnose why the power door locks don't work. I tested the door lock delay module (located behind the ecu) and it tests good. I have a feeling the voltage signal is low going from the d/s door lock to the delay module. Looks like more trouble than it is worth to try to remove the electrical unit inside the door to clean the contacts.
Doomfinger
Tires & Wheels
Aug 8, 2012 07:50 AM
crazydrugcop
Mar 24, 2011 06:15 PM
moorman
Aug 9, 2006 12:50 AM
Bleach
Mar 24, 2005 11:36 PM
