Cam advanced.... uh-oh...
Old Jan 20, 2011 | 12:16 PM
Ok, so I woulda posted this in my thread but didn'/t feel like it. This would grab more attention faster. I replaced the chain and tensioner when I did the timing, but I found out once in the motor that the rod bearings had been changed once before, and all the timing components on the car looked almost brand new, so i didn't worry about changing the gears since the teeth were straight as an arrow and there were almost no signs of wear on the guides. However once I assembled it, and I used the #1 slot on the cam gear, I slapped the front cover on and crank pulley so I could line up TDC on crank degrees, and I found my cam is ADVANCED almost 2 full cam degrees (about 6 crank degrees). Now this isn't fixable, because the other slots on the cam gear #2 and #3 are just going to advance the cam another 2 degrees if I remember correctly. Should I be worried? What are the possible outcomes? grrrrrr....
Old Jan 20, 2011 | 12:22 PM
If you turn it over by hand and the valves don't hit the pistons then you should be fine.
Old Jan 20, 2011 | 12:31 PM
Lol, yes I know it will be fine in that aspect, I'm more or less worried about performance loss or a pain in the *** idle or something along those lines. The valves I am very sure are no where near in danger of touching pistons with that little of difference... I'm more worried about second hand consequences. Running issues.
Old Jan 20, 2011 | 12:38 PM
advanced valve timing would help with the top end of a boosted car.
xBlastFemurx
May 3, 2016 12:59 PM
NotMe
Jan 30, 2007 02:04 PM
