Broken Bolt Head
Old Feb 19, 2007 | 10:05 AM
DGriffin's Avatar
Broken Bolt Head
Whats the best/easiest way to remove a bolt with a broken off head? Ive tried penetrating oil, vise grips, and putting on a nut and tightening it and even locking 2 nuts together then trying to loosen. All of these techniques have not helped AT ALL! There are 2 diff bolts like this 1 is about 1/2" up and the other is about 1/4" up. Both bolts are also very, very rusty.
Are there any tools/techniques that I can use to get these bolts out?
This isnt on my 280zx by the way but rather my grandpa's 56' ****** jeep Im helping him restore/rebuild. Plus there arent any useful forums for jeeps that old and I figure this question really applies to any vehicle. And you guys seem to also be able to help me with any other questions I have had on my 280 so............
Thanks, I really appreciate any help ya can give on this.
Old Feb 19, 2007 | 10:12 AM
Weld a nut on the end. You will have something firm to grab it with, and the heat will help loosen it as well. Hopefully you have access to a welder....
Old Feb 19, 2007 | 10:18 AM
DGriffin's Avatar
My friend im going to be roomy with in a coupla weeks has access to basically all welding equipment needed. Im not really to informed on welding, but i know there are dif kinds. what kind should I use?
also for heating it up will one of those propane torches work OK?
as always thanks nismopick.
Old Feb 19, 2007 | 10:33 AM
Just use a mig welder. Clean up the area you will be welding on, so the weld will penetrate. A propane / oxy-acetyline torch will work too.
Old Feb 19, 2007 | 10:34 AM
DGriffin's Avatar
AWESOME, thanks again man.
alphadog007
Aug 8, 2013 09:04 AM
WanganDevilZ
May 15, 2011 06:24 AM
Sevan
May 13, 2009 10:41 AM
DarrellBuddy321
Nov 8, 2005 08:33 AM
Fast240Z
Apr 30, 2005 12:49 AM
