bottle fed
Old Apr 25, 2006 | 10:22 PM
sion's Avatar
Lightbulb bottle fed
i got an 82' zx n/a and does any one know how much of a shot i can safely do that the engine can take it will be getting a new rebuilt block put in this week an in a couple a months msd just don't ever get shocked by a current transmitted by msd you will pass out .
yes it was an accident.put i am still pondering on bottle feeding her . seeing how much i would be able to do ?
thanx
Old Apr 25, 2006 | 10:30 PM
to be safe with a bottle, no more then 80.
Old Apr 25, 2006 | 10:31 PM
make sure you get the ignition first, and a better fuel pump to handle any excess needs. that way your bases are covered.
Old Apr 25, 2006 | 11:09 PM
nismo619's Avatar
i was told for a non turbo car to use a turbo fuel pump... or like a walbor 225 and to use a 50 shot to a 100 shot of noz... u might want to use IRDUIM NGK spark plugs... any other type will foul out umm do a little bit more home work..
Old Apr 25, 2006 | 11:34 PM
sion's Avatar
that really sounds nice . oh nice indeed . i was thinking of using a wet system but i don't know where to get a single fuel rail and not the trumpet like rail that is on there as the stock one .
Old Apr 26, 2006 | 02:04 PM
jfairladyz's Avatar
Using NOS is no different then turbo charging your vehicle when comes down to how the power is made. When you add nitrous alls you're doing is the same thing the turbo does: Cram in more air. Nos gets such a bad rep from people who dont understand how it works. Kind of like our friend Nismo619 here saying you need to run iridium plugs or else they'll foul out. Thats bullshit. Would I need Iridium plugs to push 50 more horsepower out of my turbo motor? Nope. At most you might need to change the heat range of the plug. Upgrade everything the same way you would for a turbo charger. The only difference is that the nitrous has an on/off switch and needs to be replenished. There only two true drawbacks to a nitrous system. One is the previously mentioned fact that it's a consumable. The other is that you have to rely on solenoids to get that extra fuel when the nos is switched on. Solenoids can fail. And when that happens it's bye bye motor unless you have some sort of pressure safety switch.
Old Apr 29, 2006 | 01:04 AM
bradyg's Avatar
he is right. it does not burn , it supports combustion since it decomposes into oxygen and nitrogen when heated.
Old Apr 30, 2006 | 10:42 PM
EatmyDust's Avatar
I was waiting for somone to make a freaking post about the hole torbo charge and nos really being the same just different methods. I lot of people really don't know that and it is strange to me when I hear the damn turbo street racers slam nitros saying that it is un-natrale. then tell me that shoving air into the engine with a turbo is.
any way I can't remember who sayed don't use more than an 80 shot, but that is good advise. I heard it is generally going to be a safe line at 75, remember this car wasn't turbo so you have to take combustion heat, and preasure into consideration. the rings could be a weak point. but the crank will handle fine.
Old May 1, 2006 | 06:54 AM
bradyg's Avatar
yea and youll blow the **** outta the head gasket too unless its high perfmance one
Old May 1, 2006 | 06:56 AM
bradyg's Avatar
this is kinda like that one convo you had with that one dip **** his name was like az-abum or somethin about the tb? i dono if that guy just cant figure out commonsence "the more air you get in your motor the faser youll go"
Old May 2, 2006 | 02:44 PM
383ZJUICED's Avatar
MY ORIGIONAL ENGINE, THE INLINE 6 HAD 196,000 MILES.
I PUT IN A MILD CAM, 1 STEP COLDER PLUGS, FIRE BALL COIL, FUEL PRESSURE REGULATOR, 60MM THROTLE BODY, FULL EXHAUST. AND I HIT IT WITH A 100 SHOT ALL DAY.
I WAS ON A McCREARY DRAG RADIAL. I COULD DROP THE CLUTCH AT 3000 SPRAYING OFF THE LINE AND DEAD HOOK.
Old May 2, 2006 | 03:00 PM
That sounds a lil over-exagerated. A 100 shot on a stock engine (20 years old and 195k miles)... All day long...
Old May 2, 2006 | 05:08 PM
jfairladyz's Avatar
I wouldn't be worried so much about the engine standing up, thats just over 200HP total at the flywheel (non-turbo of course), when all is said and done ( a 100 shot is most likely not going to give you an actual extra 100hp). But I would be worried about the stock injectors and fuel pump keeping up as they would surely be running near full duty cycle at those power levels.
GNRick
Jul 3, 2014 11:07 PM
jurickwessels
Apr 3, 2012 08:14 AM
thxone
May 12, 2007 10:22 AM
