AFM Ground wiring, where does it connect?
Old Jan 20, 2010 | 07:58 PM
bigbreak_2000's Avatar
When I bought my 1981 280zx the ground wire on the AFM was not connected at the one end (just dangling in the air). Car still ran fine. I read through FSM, Haines and can nowhere find a picture or description on where to connect the ends of this wire. Does someone have a picture or can describe to me where the ends connect? Appreciate.
Old Jan 20, 2010 | 08:08 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
uhhhh to a ground?? hahahahahaha chassis or engine i chose chassis
Old Jan 21, 2010 | 11:30 AM
It uses a body ground wire that's in the harness. And actually... if you look at the AFM wiring harness, there should be a ground coming out of the harness about a foot in from the AFM plug (unless someone chopped it... then you have other problems).
Old Jan 23, 2010 | 12:39 PM
or is he talking the short little wire thats on the afm, it goes from the afm to its own mounting screws. i know mine has one like that as well. it grounds the case to the chassis, because it is rubber mounted.
Old Jan 23, 2010 | 01:10 PM
bojo68's Avatar
+1, don't think mine has one, but if I had problems, there would be one...
Old Feb 6, 2010 | 07:07 AM
AFM gorund wire
Hi Shady280, yes that is the little wire I was referring too.
NismoPick
Jun 2, 2014 09:19 AM
Neill Solomon
Feb 8, 2013 02:55 PM
dajude
Aug 23, 2011 05:57 PM
Z32GhOSt
Feb 20, 2006 03:26 AM
theramz
15
Aug 2, 2004 10:26 PM
