83 280zxt running bad and popping
Dads 83 280zx turbo 5spd.. i posted about this a long time ago but took a break from it to regroup, car wont idle or run right, only wants to pop back and stumble. I have replaced a bunch of parts but still doing it.
New motor from fresh rebuild
new maf sensor
new injectors
new injector plugs
new spark plugs
new wires
new temp sensor in ps of head
new idle sensor (coolant runs through it on top of intake)
New tps sensor
Fuel pressure checked and within limits, shop put a new fuel pump in.
Im lost
new maf sensor
new injectors
new injector plugs
new spark plugs
new wires
New tps sensor
Im lost
i didnt put the wires on car but i will double check it, if its not that then could the timing between the crank and cam be off by a tooth or two and cause this same symptoms? Again the timing we assumed the shop had done correctly
You never mentioned this... and if a shop had worked on it and not fixed it, that's even more reason to CHECK EVERYTHING.
L28Speed
May 25, 2006 03:37 PM
